TheIHMan
    380
Everything posted by TheIHMan
  1. Deer season opens today...
    Knocked down a doe this morning, wasn't much movement this afternoon once it heated up, tomorrow will be interesting with the rain and wind in the forecast.
  2. What's your favorite crop to harvest?
    Definitely wheat, you can cut it however you want and you don't have to watch for rocks and logs like in soybeans.
  3. Fall Harvest 2017 Thread
    Yes! I saw you running that yellow test plot combine but I didn't put 2 and 2 together and figure out that it was you. Hauling corn that day which was Friday I think. I was probably moving at a pretty good clip as I was trying to make up for the morning that I lost due to the water pump grenading itself on the other 1680 that was on corn. Water pump had only 50 hrs on it and the Chinese bearings let go and broke the shaft in half, luckily it didn't sent the fan through the radiator.
  4. Fall Harvest 2017 Thread
    On beans now, lots of green stems but moisture is anywhere from 8%-11%, yields are poor (around 30) but we didn't get hardly any rain second half of growing season.
  5. tractor rental
    This one is seems pretty accurate. I have used it before. http://web.extension.illinois.edu/lmw/cat82_497.html
  6. neat tractor, anybody no whos it is
    Looks like a IH 573 to me, looks like it has 2 separate heads
  7. The holy grail. Everyone chime in.
    Sure looks like a legit prototype, the front dash is different from both the 88 series and a magnum and the cab itself is more like a magnum cab than a 88 series. Would be interesting to see the inside of it and see if it really has the full powershift.
  8. RP board meeting at HCOP
    I had a great time talking with everyone this weekend. Was awesome getting a chance to meet some great people! Can't wait to do it again!
  9. 5288
    Mike Links knows better than I do but you pull up the floor in the cab and under it you will be able to screw in two pressure gauges on top of the trans. I think the pressure should be in the 300 range but hopefully Mike or Danny or someone with a fresher memory can chime in and help you
  10. Lawn Mower Recommendation
    I have a little 618 Grasshopper with a 52 inch deck and I am very happy with it. I have a good sized pond I mow all the way around and in places where the old cub cadet would make me nervous, I just throw the sticks forward on the Grasshopper and don't even think about it, they have a very low center of gravity. If you are going to get a rider, you can't go wrong with a Cub Cadet 1811 or 1812. They have an 18 hp kohler opposed cylinder engine and are basically a newer version of the 782. They are also the last steel hood and fender Cub Cadet made.
  11. L.D. Nation on his 1066 puller back in 1983
    A few years back he had a modified with 4 hemis on it.
  12. DT Engine Torque Figures
    Funny how a na 466 makes less torque than a turbocharged 360.
  13. 407 flywheel
    Does anyone know of anywhere that makes or sells steel flywheels for a 407 motor, trying to setup our 1206 like we had it in the late 70s when we pulled pro stock with it and need a steel flywheel so we can put the high rpm pump back on it to make a few exhibition pulls with it.
  14. Remember this old 88 series literature
    Our 5288 has about 5 shades of red but it's still the best tractor to operate that we've ever had.
  15. Working in central/upstate NY this week
    Sounds like NY is like IL, there is Chicago and then downstate.
  16. Need Loadstar Info
    Cab is the same as a C series pickup, if there are any issues with the Detroit, just swap a DT 466 into it, can pick up a running 466 for as low as $1200.
  17. Red Pullers
    5.125 bore by 7.5 stroke, have to stagger pistons and fill water jackets in block.
  18. Red Pullers
    We have a 1466 4.1 limited pro, 640ci, just run state level with it and also two M's one 505ci, the other 555ci. Have plans to turn the 505 into a 620ci motor in the next few years.
  19. W9 main bearings
    Does anybody know where I could find a set of .010 under main bearings for a W9. Checked Hy-capacity and AG parts with no luck Thanks Adam
  20. Over 7 thousand pounds of front weights.
    06 and maybe 56 series weights don't have a L hole for the hold down, 66 have the L hole, 86 have the curved bottom like earlier weights but have a large hand hole, the flat bottom weights are 88 series and are actually 110 lbs
  21. The Deplorables
    It would be nice if you would respect our president enough to spell his name right. But if you believe what the media tells you that he is going to destroy our economy, sell us out to Russia, take away all gay rights and automatically deport all illegal immigrants, then you probably don't respect him.
  22. Red 4WD and Steiger Tractors Wanted for Upcoming Book
    Our 4586 before we sold it this year, the 9370, and the little 4386
  23. How many hp were 1206s new?
    Our 1206 had 138 HP the day it arrived at the dealership,
  24. Craigslist 5088
    Tires have way more than 700 hours of wear on them
