Cp 856
    240
Everything posted by Cp 856
  1. 706 no steering
    I just got a 706 diesel it has no steering. We drove it on the trailer but when we got it unloaded it quit moving if you play with it it will start moving again but still no steering. The breaks work good all the time. So my question is it the mvc pump or something else. It drove good onto the trailer just no steering. I got it from a estate auction they didn't know much about it but it had been setting a while. I am hoping it's just the pump but don't know. Thank for the help
  2. 706 no steering
    I have never seen the oil light come on so I am assuming it doesn't work. I took the lower plug out of mvc and it shot fluid while cranking it over a nice solid stream of oil. I am going to pull filter and look at it it looks like they put oil in it to move it at auction and it is at the full mark. No one knew how long it had set or why at the auction.
  3. 706 no steering
    Just got it power washed off and pulled into the shop it slobbers pretty bad out the exhaust and runs fairly smooth but has puff of smoke every time it fires on one cylinder but I think it's an injector. It still has no steering but has fluid out the bottom port on mvc. It will move on the low side of the t/a but if you shift it it either stops moving in high and low t/a or just moves the same speed as low the breaks work but not that good but feel like they have a good Pedal not really sure where to go from here.
  4. 1486 turbo
    I have a 1486 that I am replacing the muffler with an eliminator when I got the muffler off I noticed that the exhaust side of the turbo housing is pitted and pretty rough looking when you look back behind the vanes it looks pretty bad too. So I am thinking about replacing the turbo now while I have everything apart. My question is should I upgrade turbos or go back stock the tractor is my big tractor gets used for chisel plowing to running round baler and everything in between. It is set about 25 to 30hp over stock is the $400 more for a 3lm worth it?
  5. 1486 turbo
    Thanks for the help I will probably go with a better turbo than stock now I just have to decide which one
  6. Ih454
    I have the set of remotes off mine rite now because it's leaking I will look at them for numbers when I get to the farm later today. There is a plate on the side of the trans on right hand side you take off then sandwich the valve in between that plate and trans pretty simple if you can find the parts. Mine was leaking real bad I replaced all the o-rings and it still leaked so I just took it off I am getting ready to try and rebuild it. I will try and get some pics too
  7. New Holland 853 Roller
    We have a 853 that the bale command went bad on and converted it to hydrolics. All u need is two hydrolic hoses and a cylinder off of a old gleaner combine grain table. The cylinder for raising and lowering the reel has the same stroke as the electric cylinder. Only thing you have to do is drill the holes out in the new cylinder to mount it.
  8. Big Thankyou out to 2016 Red Power Roundup
    I would like to say thanks to all who put on the show and everyone who brought something to the show. It was a great show with perfect weather we were there Thursday and have spent the rest of the trip at the dells. I just want to say thanks to everyone who helped make it a great show. I have a 2 and 4 year old and all they have talked about is the show.
  9. Union Grove RPRU 2016
    Wife wanted to take the kids to great wolf lodge in the dells so I told her we should go the weekend of the 18th and 19th. Then about 2 weeks ago I told her we were leaving on Wednesday to go to the show on Thursday I told the boys first so she had no way of saying no because they were more excited to see red tractors than the water park. We will be there for most of Thursday then heading to the dells for Friday and Saturday then home on Sunday. This worked out good I am going to have to plan the family vacation around the show every year. I hope to meet a few forum members in person too.
  10. 706 High Low Shift Fork
    I finally got time to work on the tractor this week I got the range cover off and the cam and rollers and everything else looks new I think the problem is in the shift fork how much movement is in between the shift fork and the shift collar it seem like it is a lot. I have never had any problems with the tractor coming out of gear it was just too much movement in the shifter everything from the shift handle is tight this is the only thing that I find with excessive movement in it. How hard is it to replace the shift fork. thanks for the help
  11. 706 High Low Shift Fork
    This all helps I am going to rebuild all the shift bushings and linkage and start there it all felt good with what I think was minimal slop but there is something wrong somewhere because it goes into gear good and stays but you can still move the shift lever quite a bit before it wants to switch gears thanks for all the help it is greatly appreciated I will keep posting my findings it is probably something stupid I missed
  12. 706 High Low Shift Fork
    I will try and take a video to night when I get home from work. I have everything tore apart rite now for the shift lever. When you are shifting gears it feels like it snaps into gear and will move fine in reverse and low but it has a lot of free movement in the shift levers all the linkage feels tight there is a little play in the shift lever bushing but not much. It has never jumped out of gear.
  13. 706 High Low Shift Fork
    I am just having trouble getting high but lots of movement in shifter handle with very little slop in linkage when you get it in gear there is lots of movement in shift handle it seams like all the gears are pushed forward reverse is where neutral normally is and hard to put park lock on. I have to play with it to get neutral and get handle in the right spot to get into park
  14. The 706 I have has had problems shifting it will shift into low neutral and reverse with lots of movement in the shifter. It dosent have enough travel to go into high and when in neutral it dosent line up to put into park all the linkage is tight so I think something is wrong inside the top cover is there any tricks to getting the cover off and when I get inside what do I look for that normally breaks. thanks for the help
  15. 706 Range Transmission Top Cover Removal
  16. Mending a BROKEN HEART
    This post hits home for me my son was one mouth old when we found out he had a hole in his heart he had open heart surgery at 3 mouths old it was a very scary time for us. He is 4 years old now and you would never know he had heart problems now. I always donate to any heart research because 20 years ago my son would have probably not have made it. Thanks to all who donate
  17. Out of gas?
    Had the same problem with our 706 it kept getting stuff on top of the sediment bowl pipe. I couldn't figure it out at all till one day I was at parts store getting stuff and started talking to the old tractor mechanic that was in there he said get rid of the sediment bowl and pipe it up straight out of tank with a shut off valve and good in line filter I did that and haven't had any problems it runs great now I just change the filter every few months
  18. 706 Range Transmission Top Cover Removal
    Is there any tricks to getting the cover off does it have to be in a certain gear or anything special. Does it just lift rite off or do I have to pull any side covers off to access stuff
  19. 706 Range Transmission Top Cover Removal
    I have had all the linkage apart and it dosent have much play in it I thought that was it at first. It was shifting good then all of a sudden it got so it wouldn't go into high. Like normal I was not operating the tractor when it started doing it we were using it to rake hay and the guy operating it didn't say anything just kind of let me find it messed up. So I don't know if something was forced and broke or it just happened on its own
  20. What is Your EDC flashlight and Multitool/Knife?
    I carry a benchmade mini-barrage knife it is the best knife I have ever owned. I have had lots of good knives but a benchmade is the best everyday carry knife I have owned they are expensive but well worth the money. I have never carried a multi tool but always got a knife and 6in adjustable wrench with me. I have several stream lights that I carry also
  21. 706 Shifting Problems
    i am having problems with the range shifter on my 706. It won't shift into high and there is a lot of slop in the handle all the pins and good and found the slop in the long shaft going down to the transmission. So i took it apart my problem is there is a key that drives the shaft to the arm when i got it apart i couldn't find the key i think it was never in there but i am not sure i didn't hear anything fall when it came apart but i am worried it fell into the hole that the shaft rides in i tried to feel down in there for the key but felt nothing with the amount of movement in the shaft i think the bolt that clamps the arm to the shaft was the only thing holding it. When i feel in the hole all i feel is a smooth plate. How hard is it to remove the plate to look for the key i don't want to mess up the trans because of a key.
  22. Does Anyone Hand Wash or Wax Their Vehicles Anymore?
    I hand wash and wax trucks, cars, and try to wax the tractors every spring.
  23. Cordless Impact driver Milwaukee or Snap On??
    I have a snap on 1/2 at home for 5 years and a 1/2 at work for 3 years both have been trouble free and I would buy another if either quit. I don't know the price of the Milwaukee but if you have other Milwaukee stuff I would go with there's just for the extra batteries. I know Milwaukee makes a good product and the snap on is getting really expensive
  24. X-mas is coming
    My boys have 2 of the tractors they are 2 and 4 years old and the 2 year olds legs are just now long enough to push the pedal. They love them got one new and got the other used it is several years old but looked brand new when we got it paid $20 for it from a girl my wife worked with. new battery is 70 dollars and I bought a 2 hour charger from Amazon. They are well worth the money my boys love them but still like their pedel tractors too. My 4 year old loves to pull his trailer around and pick up the yard before I mow and then he pretends to mow while I am mowing
  25. Farmall C Dies
    I had the same problem on my 454 turned out it was a bad spot in the wire from the ignition to the coil it would show 12 volts when cold but when hot would drop voltage until it died
