Cp 856
    240
About Cp 856
  • Birthday 09/13/1980
    IL
293 profile views
  1. 706 no steering
    I have never seen the oil light come on so I am assuming it doesn't work. I took the lower plug out of mvc and it shot fluid while cranking it over a nice solid stream of oil. I am going to pull filter and look at it it looks like they put oil in it to move it at auction and it is at the full mark. No one knew how long it had set or why at the auction.
  2. 706 no steering
    Just got it power washed off and pulled into the shop it slobbers pretty bad out the exhaust and runs fairly smooth but has puff of smoke every time it fires on one cylinder but I think it's an injector. It still has no steering but has fluid out the bottom port on mvc. It will move on the low side of the t/a but if you shift it it either stops moving in high and low t/a or just moves the same speed as low the breaks work but not that good but feel like they have a good Pedal not really sure where to go from here.
  3. 706 no steering
    I just got a 706 diesel it has no steering. We drove it on the trailer but when we got it unloaded it quit moving if you play with it it will start moving again but still no steering. The breaks work good all the time. So my question is it the mvc pump or something else. It drove good onto the trailer just no steering. I got it from a estate auction they didn't know much about it but it had been setting a while. I am hoping it's just the pump but don't know. Thank for the help
  4. 1486 turbo
    Thanks for the help I will probably go with a better turbo than stock now I just have to decide which one
  5. Ih454
    I have the set of remotes off mine rite now because it's leaking I will look at them for numbers when I get to the farm later today. There is a plate on the side of the trans on right hand side you take off then sandwich the valve in between that plate and trans pretty simple if you can find the parts. Mine was leaking real bad I replaced all the o-rings and it still leaked so I just took it off I am getting ready to try and rebuild it. I will try and get some pics too
  6. 1486 turbo
    I have a 1486 that I am replacing the muffler with an eliminator when I got the muffler off I noticed that the exhaust side of the turbo housing is pitted and pretty rough looking when you look back behind the vanes it looks pretty bad too. So I am thinking about replacing the turbo now while I have everything apart. My question is should I upgrade turbos or go back stock the tractor is my big tractor gets used for chisel plowing to running round baler and everything in between. It is set about 25 to 30hp over stock is the $400 more for a 3lm worth it?
  7. New Holland 853 Roller
    We have a 853 that the bale command went bad on and converted it to hydrolics. All u need is two hydrolic hoses and a cylinder off of a old gleaner combine grain table. The cylinder for raising and lowering the reel has the same stroke as the electric cylinder. Only thing you have to do is drill the holes out in the new cylinder to mount it.
  8. Big Thankyou out to 2016 Red Power Roundup
    I would like to say thanks to all who put on the show and everyone who brought something to the show. It was a great show with perfect weather we were there Thursday and have spent the rest of the trip at the dells. I just want to say thanks to everyone who helped make it a great show. I have a 2 and 4 year old and all they have talked about is the show.
  9. Union Grove RPRU 2016
    Wife wanted to take the kids to great wolf lodge in the dells so I told her we should go the weekend of the 18th and 19th. Then about 2 weeks ago I told her we were leaving on Wednesday to go to the show on Thursday I told the boys first so she had no way of saying no because they were more excited to see red tractors than the water park. We will be there for most of Thursday then heading to the dells for Friday and Saturday then home on Sunday. This worked out good I am going to have to plan the family vacation around the show every year. I hope to meet a few forum members in person too.
  10. 706 High Low Shift Fork
    This all helps I am going to rebuild all the shift bushings and linkage and start there it all felt good with what I think was minimal slop but there is something wrong somewhere because it goes into gear good and stays but you can still move the shift lever quite a bit before it wants to switch gears thanks for all the help it is greatly appreciated I will keep posting my findings it is probably something stupid I missed
  11. 706 High Low Shift Fork
    I will try and take a video to night when I get home from work. I have everything tore apart rite now for the shift lever. When you are shifting gears it feels like it snaps into gear and will move fine in reverse and low but it has a lot of free movement in the shift levers all the linkage feels tight there is a little play in the shift lever bushing but not much. It has never jumped out of gear.
  12. 706 High Low Shift Fork
    I am just having trouble getting high but lots of movement in shifter handle with very little slop in linkage when you get it in gear there is lots of movement in shift handle it seams like all the gears are pushed forward reverse is where neutral normally is and hard to put park lock on. I have to play with it to get neutral and get handle in the right spot to get into park
  13. 706 High Low Shift Fork
    I finally got time to work on the tractor this week I got the range cover off and the cam and rollers and everything else looks new I think the problem is in the shift fork how much movement is in between the shift fork and the shift collar it seem like it is a lot. I have never had any problems with the tractor coming out of gear it was just too much movement in the shifter everything from the shift handle is tight this is the only thing that I find with excessive movement in it. How hard is it to replace the shift fork. thanks for the help
  14. 706 Range Transmission Top Cover Removal
  15. Mending a BROKEN HEART
    This post hits home for me my son was one mouth old when we found out he had a hole in his heart he had open heart surgery at 3 mouths old it was a very scary time for us. He is 4 years old now and you would never know he had heart problems now. I always donate to any heart research because 20 years ago my son would have probably not have made it. Thanks to all who donate
