Dillsburg 560D
    133
About Dillsburg 560D
  • Birthday 09/18/1971
    EC IL
    560 DT282,1967 806 DT361,IH 720 5-16",#16, 4-14" Plows , 1982 5088, 1978 4186, IH M1 Garand, Prefer IH but not color blind.
688 profile views
  1. Building a Sentry Module
    I hope this picture works for you. The second picture is of the one in my 5088 Case IH part doesn’t show a number on the larger transistor
  2. Building a Sentry Module
    I have 4 sitting in my shop. I will try and get you some pictures this week.
  3. Electrical issue with 1666
    Check the positive and negative cables at the batteries. I have had them get corroded inside the flag and loose contact. There is also a single wire that feeds the digital display at the batteries that goes bad. Load test batteries, have seen a bad cell do funny things in the cab also.
  4. Sept/Oct 1975
    The 1256's are long gone and I don't have any clue to where they may be. I wish I did. Thank you for all the comments. When Dad gave me this original picture and one he had enlarged and framed it brought a tear to my eye. I'm not sure what the deal was with the decal on the hood. I asked dad but he wasn't sure. By the way I was 4 when this was taken.
  5. Sept/Oct 1975
    So this is where it all started for me. This picture was taken in September/October of 1975 it went missing for quite some time. My dad found it a couple months ago and had it blown up for me. I received it for my birthday and I think this is the best gift ever. Thanks Dad for everything.
  6. Unknown IH shop tool fluid dispenser
    I have one that is yellow with the IH decal on it. I will try and get a picture tomorrow evening. Cool find.
  7. 7120 combine a/c evaporater
    Check the right side where the evaporator slides into the cab. Make sure it is sealed up good.
  8. New to me 4186
    Thanks, 28L-26
  9. New to me 4186
    Yes
  10. New to me 4186
    I have the original owners manual and have been looking through it.
  11. New to me 4186
    Yes, we have been using our 5088 for all tillage and planting. This will allow us to work ground right ahead of the planter now. Instead of possibly drying the ground out before the planter can get to it. Very small farm here.
  12. New to me 4186
    It's pretty flat where we live also. That was in the list of things to do.
  13. New to me 4186
    Brought this old girl home tonight. Anyone with any tips or advice? I know the steering is something to be desired and don't want to hear to get rid of it. Thanks for the advice in advance.
  14. Power steering kits
    It may be the cap wire you are describing. Just a piece of square wire to hold the cap in.
  15. 7120 tractor hot hyd oil
    Are your rear axle housings hot to the touch? If so your brakes may be dragging. To correct this blow the dirt off the top of the brake valve on front of the cab. Then adjust to where the pins are free to spin. If you had a temp gun that would help. Hydraulic Oil will run about 100* over ambient temperature from what I have been around. Good luck
