farmall57
    719
Everything posted by farmall57
  1. IH 537 manifolds
    Could very well be....I don't have a parts book that has the V537 in it, and that 448238C1 number doesn't show up and in any of the books I do have.
  2. IH 537 manifolds
    The V537 was the same engine series as the V605. The DV462, DV550 series was the diesel version of these. Completely different engine series than the 401,461,478,549 engines. I do notice that the exhaust manifold gasket is same for both 537 and 605, so guessing the manifolds were same as well. I do not know if the DV550 exhaust was the same or not. The 605 was a very popular engine for irrigation, so I'd sure try calling some of the irrigation engine service places in the big irrigation country. Duerst Machine in Burlington, Colorado would be one to try, (719) 346-5348, at one time they had a rather extensive irrigation engine boneyard.
  3. Dream job...?
    When I called the Wisconsin Historical Society to order Line Setting Tickets for several of my IH trucks, I told the guy he had my dream job. I would go absolute nuts in there with all that IH information!
  4. IHC 345 cc engine distributor wire question
    The resistance wire that IH used is usually fairly obvious where it comes out of the harness at the coil and also at the firewall. It has an odd asbestos/fiberglass type braided white covering. It is made right into the harness with the rest of the wires.
  5. IHC 345 cc engine distributor wire question
    The one from the coil to the distributor would be just wire. The one from the key to the coil will have a resistance somewhere, probably the section from the firewall to the coil is resistance wire unless it has a external resistor block.
  6. Farmall Parts
    Matt, the only thing I can think of is you aren't scrolling the list to the bottom or not going on to the second page. Should look like this:
  7. Farmall Parts
    On the CIH parts web site, when you get to the "find parts by model" web page, click the "browse" button up by where it says "find your model", then go to "tractors" -- "utility" -- "legacy". There are 2 pages, all the Farmall A, B, C, H, M are there, and Supers, be sure to go to the 2nd page too. It's obvious the who ever set up the pages had no clue what the various models were and where they should have been put, but I am very glad that it is online even if it's a little work to figure it out. If you create a "My Shed" login and enter your tractor models, it will populate the home page with all of your tractor models automatically each time you open the parts web site.
  8. Artic Cat 550 one way clutch question
    I have both, a 2008 with Suzuki and a 2012 with Arctic Cat. Oil filter on the Suzuki points straight out the front, Arctic Cat points upward about 11 o'clock.
  9. Old flat belt pulley identification
    Yes, the M1 sure would look like a Massey number. McFairlanes does sell Massey, maybe Ritchie's did at one time?
  10. Old flat belt pulley identification
    If you Google that 500871M1 part number, it comes up on Marketbook as in stock at Ritchie's Implement and at McFarlanes, both farm equipment dealers of various brands in Wisconsin, and calls it a hub, not sure it would be the same but might be interesting to call them and see if they could tell you what it fits.
  11. Heat Gauge
    This is something that has always bugged me. It takes the same effort and equipment to make the gauge wrong, why not just do it correct from the start? They obviously copied an original gauge so they have to know it's not correct.
  12. Sadly, IH to Claas combines
    I've posted pictures several times and we've discussed the Linnebur farms at Byers, CO where he would line up 12 -20 IH combines each year prior to harvest. I've driven by this for the last 25 or so years and looked forward to seeing all this take place. Well, Gene Linnebur died a few years ago and I don't know who is running things now, but sadly, no IH combines this year, they have been lining up Claas combines since early this spring. I took a (poor) picture when we drove by the other day, just doesn't look right without those red combines all ready to go.
  13. Couple of IH Prototype Buildings Still In Use
    Sadly, the iconic IH building in Bridgeport, Nebraska is now the "reconditioning center" for the Deere "21st Century" chain of stores.
  14. Softcore Roundbalers any good?
    I have a New Ideal 486, Biggest Pro for me was you never even needed to look back when starting a bale, just drive. Biggest Con was I could not unroll them with a bale bed because of the too soft center, they would always want to just drag instead of roll.
  15. Car trivia
    Chris Ledoux has another song called Montana Rodeo, there is a line in the song, "There are some college boys from Missoula here, school has just let out, they got a keg of beer on a tub of ice in the back of a BRAND NEW SCOUT"
  16. Interesting reading
    Some of those are readable or available for download off the Wisconsin Historical web site. Right side of the page where is says "catalogs" Wisconsin Historical McCormick Collection web site
  17. Red Power Mag
    I got Red Power, Harvester Highlights, and Corn Binder Connection on the same day!!! Talk about IH overload!!
  18. Found the scout honey hole in Tennessee!
    Poor guy, I can see he has the same disease that I have
  19. 1975 IH 4X4 Pickup
    It didn't come with that box, it says "PICKUP BOX 8 FT BL" Code 16509, that is the "bonus load" wide box.
  20. 195? Fire truck L 185 Serial number help
    I'm reading that differently, what I see is the beginning serial number for the L185 model on January 2, 1952 was 8824 so this serial number (11174) was made after that, probably toward the end of 1952. Production of the R185 started January 1953.
  21. 666 zenith carb
    This may be a crazy idea, but we had a 101 combine (C221 engine) that for some unknown reason got to running too rich. We had the carb off several times cleaned it all up and still same. The angled plug on the bottom of it that lines up directly with the main jet was just a 3/8 fine thread. Dad took a common 3/8 fine thread bolt with fibre washer and lock nut and run it up there against the main jet, as you'd screw it in you could hear it get leaner and rpm increase, we'd pick a spot that sounded about right and ran i like that for years and years. You'd have to tweak it once in a while for different conditions but it worked just fine. I never understood what changed as it ran fine for years before but that was our fix, maybe worth an experiment?
  22. Changing controls on Hydro 186
    Maybe IH hired the same guy who put the hydraulic and hitch controls on the dash of the 3010, 4010.
  23. questions about a S1600
    And to complicate matters, if it was a U-Haul truck parts can be especially challenging because the ones built for U-Haul didn't necessarily have standard parts. There were quite a few special spec parts for them, a Line Set Ticket will be a real help for sure.
  24. Super H clutch
    In the 70's I worked at a "green" dealer that sold Yanmar, lots of the little bit larger then garden tractor sized ones. They came crated with the clutch tied down. They'd get sold and guys would take them home run them a few days and then put them away. When they fired them back up the clutch would be stuck. We would try putting them in gear and bang them into the dock and various other ways to try to get them loose. Most of the time we ended up splitting them and you could pop the disc loose with your fingers, but no way they'd come loose otherwise, always amazed me. They started telling people to tie the clutch down if they were going to sit awhile. I always figured it was from the salt air in the shipping over here.
