660 driver
    8,336
1 Follower
About 660 driver
  • Birthday 09/06/1978
    Red Wing,MN
    Tractor pulling and workin on old binders. 660,F-20,30,14,12,W-30,460gas,1947 M,22-36,'53 Super M,IHC model "M" hit and miss,IH 140,and a '68 cub cadet 125,'76 966bs with hinker cab and M&W turbo,cub 154 loboy.
  1. Nice pics jerry and i didnt get a ride in golf cart in iowa.....if u make to alabama i may bum a ride from ya!
  2. The marks are on the crankshaft pulley not the fan pulley. U will scratch all day and only find the marks u made.
  3. Oh ya they can be much cheaper. But the driveline and live power shaft are the weakpoints and very expensive to fix. Like i said mine has new clutches,live powershaft,and bearings. I would.get it with small rubber like mine. Lowers the ground speed so you get all the torque you can out of the engine. They are a touch higher geared so maximizing engine torque is a must. Ours runs the 60" deck in taller lawn grass in 2nd gear with no issues. Has 3 gears. 3rd is roadgear. If you find one with 3 point and a creeper drive you have a gold mine!
  4. We paid over 3g for this one with 3 point and deck. It has many new driveline parts including all clutching. Deck is like new. These engines are simple they are flat head inline 4's. As long as you dont expect them to do the work of a super c or c they are great little machines. I put electronic ignition on mine and it starts without choking evertime.
  5. Yes happy bday!
  6. It could be off a number 6 or number 8 mccormick deering horse drawn sickle mower. It also could have come from a corn or grain binder. Anything thay needed regular oiling would have had that box. We have multiple implements with that type toolbox/oilcan holder. If i had to guess 20's or 30's vintage but thats just a guess. Nice find sir!
  7. Do what you love i say. If running a dairy is your passion the git after it! Only one farm near me i know of with bots and i dont know if its still going. We chopped late hay there about 9 years or so ago. Was a neat setup but the initial investment is steep.
  8. Happy bday guys!
  9. Does it even sputter or try to start? Could just be far enough out of time where it won't start. It would still have spark just not in the correct sequence. How is the fuel flow at the carb? Screen in line at carb? If it has spark,air,and fuel it has to run so one of those things is missing or grossly misadjusted. No gas smell tells me its not getting ANY fuel. Check your fuel flow at carb and if none there work your way back to the tank. Check to make sure air cleaner is not plugged.
  10. I know a couple of local guys too that might have what you need if you can't find it elsewhere. You will just have to PM me if thats the case.
  11. all states ag parts is one. I cannot for the life of me remember the name of the other place I'm thinking of......maybe it will come to me.
  12. Good hook KRM!
  13. Have multiple rough sawn blocks we use. Weigh a crapload but could support a battleship!
  14. Time and pressure will be your best bet. I heard once that kroil is good but I use PB blaster with good success.
