Tedb6804
    33
About Tedb6804
  1. H gauges and decals
    I am starting to gather some parts for a late 1946 H project. Serial number is 239207 which makes it a late 46. Most casting dates are November or December or 46. I have no way to know if they are original but the oil pressure and temp gauges have the IH symbol not the IHC symbol. The new gauges I have found show the IHC symbol through 46 and changing to the IH symbol in 47. Since the current gauges have the IH I think I will stay with them. The decals are long gone but I think they should have the "McCormick Deering" and the IH symbol which Bates sells. The "Farmall Letter Series" book says this style decal was used from "about 1946-1947 to July 1949. I am sure these topics have been discussed but would like to confirm. Hoping to be as correct as possible. Thanks
  2. New c with carb trouble
    The grill also indicates a super C.
  3. McCormick #50 Power Loader
    I have one of these loaders that came off of a 460 Utility. I can't find much information on them other than this ad. Looks like it could fit 300, 350, and 460 utility models. The loader seems fairly well built and has down pressure on all cylinders. Currently don't have a tractor it will fit and not sure I want to buy one just for this loader. I would imagine it would be a hard sell as well. Just curious if anyone has any experience with these loaders.
  4. International 2001 Loader
    Thanks for this information. Was hoping they would be more universal. Probably be tough to find sub frames and brackets by themselves without the loader. Be better to find a complete unit for the correct model. It looks like the sub frame for a 460 utility would work on a 606 and vice versa but that's it. Am I understanding that correctly?
  5. International 2001 Loader
    I haven't been around these loaders much. Was there multiple versions for different models or was there one standard unit that used different brackets for mounting. Specifically I am curious if the same 2001 could be used on a 460 utility or a farmall 460 with the correct brackets. I am not sure about the frame lengths to for the rear axle mounts but is the loader frame length adjustable? Thanks in advance
  6. 1975 model 966
    Did any black stripes have the louvers on the side panels?
  7. Opinions on cut out relays
    Thanks for the ideas, just curious what others had done with their tractors. I could be wrong but according to the serial number cutoffs on the Stiener Cut out relay it looks like they were used on most models until around 1950.
  8. Opinions on cut out relays
    I am getting close to start a 1946 H project that originally had a cut out relay and 4 position light switch. I am leaning towards going to a voltage regulator and a 3 position switch. I am sure this has been discussed before but thought I would start fresh. I think I have also read about differences in the generators between these two systems. I like to keep things original but the voltage regulator setup seems to be a lot more fool proof. Thanks in advance for any adivice
  9. 1206-501
    I may have missed this but is it known how many prototypes where built? Would this have been in 1963 or 1964?
  10. 1206-501
    The ebay listing has a few more pictures now.
  11. 1959 460 LP gas Hi Utility
    Thanks for the information, I have made some phone calls and think most of the parts will be fairly easy to come by except the tank. Is that LP in Texas? Is it for sale? I think the loader is a McCormick number 50 as well, not sure if it will still fit with the LP tank but would be nice to fix up and maybe keep together. Let me know your opinions.
  12. 1959 460 LP gas Hi Utility
    Yeah, don't think they knew what they had. Hope I can find the LP tank for it but going to be hard. First thing will be to get the loader off of it.
  13. 1959 460 LP gas Hi Utility
    Thanks, maybe someone has a 460 lp utility that wants to convert to gas.
  14. 1959 460 LP gas Hi Utility
    Bought what I believe to be 1 of 13 460 LP Hi Utilities. Down side is it was converted to gas at some point and has a pretty bad paint job. Not sure what my plans are with this tractor but plan to start searching for the LP tank, hoods, and other needed parts to convert back to LP. Or look for a regular LP utility to swap parts from. If anyone has any leads on those parts it would be appreciated. I have attached some pictures to get some opinions. I thought the loader might be a schwartz but have not seen one like it before, if anyone could help identify it that would be great. Thanks, Ted
