farmer686d
    46
About farmer686d
  • Birthday 12/04/1984
    Loganton, Pa
    IH tractors, New Holland equipment, 2 stroke Detroits, farming, wrenching, hunting, tractor pulling, Packers football
397 profile views
  1. Power beyond plate Farmall 656
    No room, the fittings will hit the rockshaft control lever.
  2. Stock Air Intake vs Donaldson
    The Donaldson top spin is nice because dirt falls out the bottom, no bowl to maintain, Turbo 2 is similar. They improve filter life significantly, I have seen the SP forage harvester and New Holland used them for years on their SP windrower.
  3. Power beyond plate Farmall 656
    It's the end plate from Bates Corp, in my ignorance I neglected to check how close the outside valve was the the rockshaft control quadrant. Looking for ideas.
  4. Stock Air Intake vs Donaldson
    Companies have found cheaper ways to aspirate the air filter, whether through suction from the exhaust, or the cooling far draw, ans also now most machines have the no external air stacks.
  5. Deleting double posts
    Any way for the creator of a posts to delete the post if the system creates two identical posts?
  6. Power beyond plate Farmall 656
    Trying to put a power beyond plate on my 656, it has two remotes on it now. There is very little room to put the plate on due to it being close to rockshaft controls, let alone run the hyd lines out. Is there any recommendations for a way to move the rockshaft control quadrant out and extend the shafts that run to the levers? I know there are other places to tap into the system, but I am not interested in going that route.
  7. 1440 electro-hydraulic conversion
    I have read this. I really just want to be able to raise the corn head without letting go of hydro lever in the process.
  8. 1440 electro-hydraulic conversion
    yes it does.
  9. 1440 electro-hydraulic conversion
    I have a 1440 that is mechanical header float/header controls, I have a parts machine that is electro hydraulic. Can I put the electro-hyd valve in place of the current mechanical valve, install the newer propulsion handle with the switch, but still use the mechanical lever to control the float for the flex head, or do I need to find a Shaver kit to do this? Can you easily swap everything to do a full conversion to electro hydraulics?
  10. Is it possible.....
    I haven't seen, but have been told. They take a 6 row head and lop the inside(left side) two rows off, this gives them the correct offset to still fit on the feederhouse without any modification there, and clear the tractor tires.
  11. Farmall 656 steering
    Thanks for the hint, I dug through my service book and found this test, guess I know what I'll be doing soon.
  12. Farmall 656 steering
    Looking for direction: Steering wanders right going down the road, and when planting, requires continual correction to stay in a straight line. Tie rods are good, minimal front end play, I am pretty sure its a hyd. problem. My question is would it be the seals in the bolster, the steering motor, or the control valve. Thanks.
  13. 706 battery upgrade
    I have a single group 31 in my 656, it has never not started here in Central PA. It is a pretty fresh engine and working glow plugs, it doesn't crank the fastest, but it always fires.
  14. Learning alot, but want more info
    This a good quote, not forgetting though that the quad range was the same synchro-smash trans from the 4010 with a plantery shift infront of it and TREMENDOUS overlap in speed ratios. And the 90 series Case, which auto shifted back to '1' when the clutch was pressed, and sounded like a bomb going off in the trans when the powershift changed speed. They both were hard to change ranges, just like IH, and they both had trans technology that dated to the early 60's. And don't forget, Deere did not design the 8 speed powershift, that was designed by and outside group, was first installed in the Select-O-Speed Fords in the 50's. The 86 was a pain to shift, but there was only one ratio that overlapped, its a shame the TA couldn't have been more reliable.
