hector gemme
    399
Everything posted by hector gemme
  1. UD 554
    The ud554 should be like the TD18 motor and should be 1945 t0 1958 ?
  2. International td-20
    HI If you can't find some parts for this carburator am still have one carburator and he look like in good condition.( 251414r92)
  3. TD9 final drive removal how to.
    Yes these 3 bolts have to be removed
  4. TD9 final drive removal how to.
    Yes after the outside bolts ben removed
  5. TD9 final drive removal how to.
    You should have 3 or 4 bolts rear the flange stering and are bolted to the final drive housing
  6. UD 18 American Bosch pump
    I have a parts manual UD18A and have a AMERICAN BOSCH injection pump
  7. You could check the air filter condition for black smoke and for white smoke the fuel is't burned on pistons , let turning the starting engine more long time
  8. TD6 head gasket
    The injector pump should have a oil plug level on side and about carburator I should have one on racking if can help.
  9. International T4 and T5 orchard tractor
    I am sorry I can't find these parts these was on racking but some parts ben move in a other shop and I recheck in weeken and comback monday. HECTOR
  10. International T4 and T5 orchard tractor
    I check tomorrow I maybe still have these parts on rack
  11. td-20
    I have no carburator kit but have a complet new carburator for TD20 PART NUMBER 251414R92 for sale
  12. I have no BOSCH PUMP serie listes and I dismantled a BOSCH pump and mine nomber is APE4A-90P320 K601 and governor housing CV7954-1C-----CV79J1G-1 AND ON TRANSFER PUMPCVA225-PK2
  13. This BOSCH injection pump is for TC-51 --WR-9S-WD-9-WDR-9 TRACTOR --268182R91
  14. TD20 200 Series find
    Take care If you start your machine direct you gone crack the heads
  15. UD-16 550 adams grader
    Let me know wich parts you are looking for your UD16 motor maybe I could help
  16. TD9 Carburetor
    I am sorry can't tell you
  17. TD9 Carburetor
    This is the primer connection plug and this carburator should be for ID9-WD9
  18. Td9 series b steer clutch removal
    I never use the compress tool to removed stering cluch on TD9
  19. TD Something pictures 5/6 ?
    The td5 is 4 cylinder full diesel and td6 is 4 cylinders too but starting on gas and transfert to diesel
  20. TD-20
    The td24,14,15,18,ud 16 should have the same mark on flywell and should't have more mark on flywell
  21. TD-20
    I think the mark in photo is for the magneto and a timing adjustement injection pump is provided on the injection pump drive between the booted coupling and injection pump
  22. TD-20
    Check in your service manual section 13a page 3 to 5
  23. td9 track won't turn
    You need to removed the stering cluch for getting the inner housing you have 3 or 4 bolts inside
  24. TD-9 Questions
    If you start your machine with ether you could crack head
