kevinj
    331
Everything posted by kevinj
  1. Changing ta unit!
    I don't think it will much matter, either dropped on yer toe is gonna leave a mark!!!!!!!!!!!!! One has to be sure and use some type of proper rigging. If that part is not understood then the work should be hired out.
  2. Changing ta unit!
    Sound like yer good ta go!!! Done my 560 some time back, easy job in the shop. I got a rebuilt unit from Devons, with gaskets, seals and such.
  3. Good muffler
    Thats what I have on my tractors, so far so good plus they sound proper compared to a Stanley.
  4. Might want to check the trans oil level, looks real dry in there too.
  5. Any of you guys heating boiler experts?
    You need to find the leak!!!! You are damaging the system. Also the low water control MUST be in working order for safety. You really need a good qualified professional to work on the boilers and be sure they are safe.
  6. MD not starting
    You do have the throttle closed when on gas, right???? Throttle only controls diesel. If open it will pump diesel.
  7. Spit and quit on M
    Pete, good advice but I find the load screw needs to open about an extra 1/2 turn in the winter. I do not work it hard enough in the winter to get it real warm either.
  8. TA
    Get TA manual, not that difficult. Devons and others offer a rebuilt unit. You really need to find the problem as it could be in the transmission too.
  9. TA
    Sound like you better get it split and find the trouble before there is more damage.
  10. Spit and quit on M
    open the load screw some more
  11. Change is SOMETIMES better
    Ginger Zee was our local weather girl, then went to the big time......
  12. Time change
    That is very well stated!!
  13. 560 Diesel power
    They are still a faster, hotter plug and I use about 1/2 of the IH recommended times if the engine is cold. If it been running it only needs a few seconds. The DRX plug is supposed to be self regulating and I have tested that, the amp draw does drop as they heat up.
  14. 560 Diesel power
    Do you have an alternator??? I think they burn out holding them on after start as the alternator hits them over 14 volt and they are rated at 11 volt. I have had no issues since i get off the button soon as it fires, if smokey, let it die and try again.
  15. 560 Diesel power
    They are available from inj pumped?????? He replied above.
  16. Debating about down sizing trailer
    My permanent plate for a 14k was either $75.00 or $150.00
  17. Debating about down sizing trailer
    Doesn't PA have a personal use exemption???? Here they follow the Federal guidelines.
  18. Rantoul or Bust
    Not this year, we are going to Buckley to see the Snow engine.
  19. 560 diesel slobbering out the exhaust
    I had one break a rocker arm, messes with compression and the fuel don't burn. Is your timing set right? You also mention it is turned up, you may be over fueling.
  20. 560 diesel slobbering out the exhaust
    Have you done a compression test?? You may have one not firing.
  21. Not as Red anymore
    Are those some type of brace on the light bar?
  22. What is this tool for ?
    Kinda looks like a body spoon
  23. Grill/bbq
    Another vote for the Holland
  24. Maxxum A/C low pressure Schrader valve gone
    Vandals????
