Dan Robinson
    359
1 Follower
About Dan Robinson
  • Birthday 11/23/1993
    Mechanicsville,IA
1,324 profile views
  1. Corn Picking with the 14P and Farmall H
    Thanks! It's on an H presently but it goes back to the owner, he let me bring the whole thing home and unmount it. The 24 will eventually go on an M or MD for next fall.
  2. IH mounted cultivator id help
    I bought 2 461s last spring, one has the late style cylinders and the other has the early style, long rod/tube style. Here's a pic of the late one this summer.
  3. Corn Picking with the 14P and Farmall H
    Nice 14P! I would like to try a little check corn someday to say I did. Last 2 year we've planted 10 acres of wide row to play with corn pickers. Here's a pic of my #24 I picked up this past sunday.
  4. 1456 tach drive
    Go to a salvage yard, the are the same from a 806D-1456.
  5. Funny noise in my new to me M-TA Thought is was an axle bearing, but...
    I think those are the stars to knock the sand out of the castings when they were made at the factory.
  6. IH 1026 Hydro Registry
    Here is a local 1026. Still owned by the same family that bought it new. Has 14k plus hours, while still being used a couple times a week. Has 6 bolt front wheels, clamp-style rear castings, fast-hitch, non-tilt wheel. I have expressed my interest in trying to acquire it someday, but the one grandson would like to restore it someday. Its the only demo that I know that is original to the area. Located near Mechanicsville, Iowa
  7. RPRU 1206 Beauty Des Moines
    Here's the tires.
  8. M with MW transmission 9 speed
    An M&W 9 speed gives you 4 extra gears between the standard 4th and 5th.
  9. RPRU 1206 Beauty Des Moines
    Just an awesome 1206!
  10. Looking at buying 1026
    I was thinking possible Demo also. Precleaner looks like there may be gold coming thru, unless it's just primer. Looks like a pretty straight 1026! I myself would keep the cab on.
  11. Sloppy shifters
    I always take the old bushing out of the shaft when replacing and put it in the new shaft. One less thing you need to buy and the bushing ist doesn't wear that much.
  12. Front Spindles Angled Differently 56 300U
    Do you have 2 rims that have different offsets??
  13. Side by side @ rpru
    Yes UTV's are allowed, just no 4 wheelers. You will have to register it at the administration building I believe.
  14. 540 1000 PTO Seals
    National seal # 472258 is all we use in the PTOs we rebuild. A lot of the aftermarket kits come with the cheap blue or green seals. Nationals have twice the thickness rubber then the blue or green usually.
  15. Looking For A Good Route To Des Moines
    I live 2 miles south of Hwy 30 at Mechanicsville. I don't believe there is any traffic cams in CR along 30. I think they are all up in town along 380. Hwy 30 is a bit rough in spots. It's 2 lane from DeWitt to Mt. Vernon. 4 lane from Mt. Vernon to about 15mi west of Cedar Rapids. Then 2 lane from there to Tama/Toledo. 4 lane from there all the way to I35. Could cut down to DSM from Hwy 30 on Hwy 330. Quickest way across Iowa is definitely I80. Any more questions about the eastern half of IA send me a PM. Hope to get to see/meet you again John!
