GaryhMN
    821
Everything posted by GaryhMN
  1. 9130 cab fan
    Got the new fan motor in with some help . Very stupid design hope this motor lasts along time. Now the inside liner of the air heater was starting to come lose . Looked to be like rubber mat with some foam it. There must be moisture in there because bolts were rusted. Do not want something that you have to sit in moldy smelling air.At the same time it is not too far engine heat . Do not know if pink foam board or plastic with foil on one or both sides will stand the heat. Parts show that 24 by 19 piece at $80 . Could use tractor cab liner Menards have air bubble inslation with foil on both sides or fiber glass with foil on one side or fire wall materal. Any ideas? nVery
  2. combines in your life
    Also 73 we had A6 case 75 case wanted to go IH but could find one that we could do small grain with pickup. Got a 300 MF (not much better than the case in small grain)Then 510 MF good machine but dealer was weak and parts were real high. Now a 1640 new in 1991 will be my last machine. I have run a pulltype JD Gleaner 303 and 403.
  3. Someone has to do it
    Thataboy the world needs to know that farmers something else but green.
  4. 886 repower
    As As I understand there are alot of differance internally between truck and tractor engine or maybe just crank. I have had many problems with an overhaul on this engine. Broken and cracked sleeves scored pistons and it was never worked hard.I was told sleeves needed to be honed and other oil jet be opened as a turbo engine.Good luck I have way more invested in the engine than what the tractor is worth
  5. 9130 cab fan motor
    While doing fall tillage smelled something hot heard it rumble but that cab is hopeless either too hot or too cool no fan windows steam up.So fix it before it is put to bed for the winter but how do get that motor out ?????.The 86s and combine take the cab top off and there is the fan motor.Well took big front plate off side plate took off fan rotor took plate off inside (some one been there some different bolts that twisted off)Can move motor but how does it come out?
  6. 9130 cab fan motor
    Thank you for the infro. I am still having problems may have to cut shaft but then it will be hardto get the fans on the right spot maybe the big one is not where it should be. Sure would like to have a talk to the man that designed that system.
  7. 527 DMI
    When in the ground the main frame should be level . Set by the hitch run the front disk in the green put the right amount of spacers get them go deep as you can but watch the gauge. I use covering blades on main shanksto move as much dirt as I can . I stop and use an old tire wrench and check how deep main shanks are going . I go about 14 in be low ground level . They like you run 5mph Will give 9130 a good load.
  8. 3" sickle speed
    Have a1020 20 ft on a 1640 doing 15 in skip row . Did not change speed from 1 1/2 and run between 3 to4 mph no problems.
  9. Concrete sealer... yes or no?
    I put a sealer on my new shop floor but was told to wait two weeks. There many kinds Menards have some .I sprayed it on with a small garden sprayer and squeeged it.I got it at a place called Carrols . When I spill oil I put oil dry down but it will leave a stain.Some get real spendy.
  10. D 360
    Get all the information you can I have alot of problems with my 360 since it was overhauled . Cracked and broke sleeves scored pistons . Last the tec school put in all new sleeves and oil pump. It now was on dyno after last overhaul . It pulled 1000 sprayer and 6 row stalk chopper.
  11. Case 8455 Round Baler
    Do not know what is in there may have a blown oring somewhere. Lookup Messicks or a dealer parts on internet. I have a 8450 and all at once I think one gate cylinder went bad.
  12. Case 8455 Round Baler
    IS the pressure knob tight ? Second knob used to release pressure on belts.
  13. Sickle mowers
    I would guess the 60s.Bought a 120 with tail wheel for $475 few years ago now I know of some for $750
  14. John deere 6620 trying to clean wheat wheat
    You maybe have wide wire concaves.On the MF 510 they closed the first few spaces of concave they were welded on bottom side. The MF also had pieces that could be put in on top of wires. I had the same thing with 1640 . I got plates that close the first two sections of first concave. It sure made a differance.
  15. 810 pickup head belt?
    I too have one that is part way open . Took two one time to a place that had forage equip. Belt feeders type things but same as baler lacing
  16. Glyphosate surfactant
    I got all liberty bean this year put atority(sp?)first after planting early June one qt.liberty this week another qt liberty. Am happy so far after the mess I had last year with solid giant rag weed where I tryed first rate flexstar and roundup.The liberty seed was less than other .I am not a fan of banvil. Knew this was going happen with roundup on everything
  17. What does this tube assembly fit?
    Hyd pipes 300 350 or 400 450
  18. Case IH 9330 front axle u joint
    We lost the front half of the drive shaft on a steerable and got one at aplace called Catco now adifferant name.They sold truck parts drive shafts and trans.and hyds.the crosses $90 dealer wanted $200
  19. It's a dusty job, but someone has to do it
    I also used my drag alot this year . The ragweed was growing so after a trip with digger and a few days latter a trip with drag set sharp before planter but I think they are rooted deep .Not sure if it was right thing to do after bean were planted I sprayed then went over with drag set almost flat like a poor mans roller . Leveled out nice rolled dirt out of corn roots not as fine surface as rolled fields i
  20. Swap meet find
    I remember you showing to me would nice to find some good SM mufflers reasnable
  21. Hamilton bobs
    Have done work on pto clutch and shaft and needed information BOB was not there at the time and he called me back on a Sunday morning . Very good service
  22. Belly pump
    I have found there is a differance in pump housing between M and SM. I took a live pump off one SM and put on a I have found there is a differance of the housing of pump between M and SM. I took live pump off one SM and put on a SM that had belly pump and wanted to keep the belly pump . Got a pump from an M but it would not fit because SM bigger clutch.
  23. Do I have to leave the forum?
    Had one for awhile to run a feeder wagon though it would be better if you had a longer left leg . The hand clutch was jumpy found a 340 INPTO worked better
  24. alternator on the 350?
    I think I turn the gen . bracket up side down
  25. ih 60 shredder
    Had a 50 that was 540 could run it with a 350 You may have to open the gear box to see gears unless pulleys are differant
