GaryhMN
    815
About GaryhMN
  • ICQ
    Nicollet,MN
780 profile views
  1. 527 DMI
    When in the ground the main frame should be level . Set by the hitch run the front disk in the green put the right amount of spacers get them go deep as you can but watch the gauge. I use covering blades on main shanksto move as much dirt as I can . I stop and use an old tire wrench and check how deep main shanks are going . I go about 14 in be low ground level . They like you run 5mph Will give 9130 a good load.
  2. 3" sickle speed
    Have a1020 20 ft on a 1640 doing 15 in skip row . Did not change speed from 1 1/2 and run between 3 to4 mph no problems.
  3. Concrete sealer... yes or no?
    I put a sealer on my new shop floor but was told to wait two weeks. There many kinds Menards have some .I sprayed it on with a small garden sprayer and squeeged it.I got it at a place called Carrols . When I spill oil I put oil dry down but it will leave a stain.Some get real spendy.
  4. D 360
    Get all the information you can I have alot of problems with my 360 since it was overhauled . Cracked and broke sleeves scored pistons . Last the tec school put in all new sleeves and oil pump. It now was on dyno after last overhaul . It pulled 1000 sprayer and 6 row stalk chopper.
  5. Case 8455 Round Baler
    Do not know what is in there may have a blown oring somewhere. Lookup Messicks or a dealer parts on internet. I have a 8450 and all at once I think one gate cylinder went bad.
  6. Case 8455 Round Baler
    IS the pressure knob tight ? Second knob used to release pressure on belts.
  7. Sickle mowers
    I would guess the 60s.Bought a 120 with tail wheel for $475 few years ago now I know of some for $750
  8. John deere 6620 trying to clean wheat wheat
    You maybe have wide wire concaves.On the MF 510 they closed the first few spaces of concave they were welded on bottom side. The MF also had pieces that could be put in on top of wires. I had the same thing with 1640 . I got plates that close the first two sections of first concave. It sure made a differance.
  9. 810 pickup head belt?
    I too have one that is part way open . Took two one time to a place that had forage equip. Belt feeders type things but same as baler lacing
  10. Glyphosate surfactant
    I got all liberty bean this year put atority(sp?)first after planting early June one qt.liberty this week another qt liberty. Am happy so far after the mess I had last year with solid giant rag weed where I tryed first rate flexstar and roundup.The liberty seed was less than other .I am not a fan of banvil. Knew this was going happen with roundup on everything
  11. What does this tube assembly fit?
    Hyd pipes 300 350 or 400 450
  12. Case IH 9330 front axle u joint
    We lost the front half of the drive shaft on a steerable and got one at aplace called Catco now adifferant name.They sold truck parts drive shafts and trans.and hyds.the crosses $90 dealer wanted $200
  13. It's a dusty job, but someone has to do it
    I also used my drag alot this year . The ragweed was growing so after a trip with digger and a few days latter a trip with drag set sharp before planter but I think they are rooted deep .Not sure if it was right thing to do after bean were planted I sprayed then went over with drag set almost flat like a poor mans roller . Leveled out nice rolled dirt out of corn roots not as fine surface as rolled fields i
  14. Swap meet find
    I remember you showing to me would nice to find some good SM mufflers reasnable
  15. Hamilton bobs
    Have done work on pto clutch and shaft and needed information BOB was not there at the time and he called me back on a Sunday morning . Very good service
