tractorman21
    60
About tractorman21
  • Birthday 07/29/1964
  • Yahoo
    Perdave100@yahoo.com
    Chesapeake,Va.
341 profile views
  1. 1330 Transmission Controls
    Hello, I bought a 1330 cub cadet mower and the transmission controls seem to be acting funny. The mower wants to move forward when you start the engine and moving the control lever doesn't seem to do anything. The mower doesn't seem to be very fast going forward and it will not back up. The rear end was replaced in the mower, but I don't think the linkage is mounted correctly. I have tried to find some photos that show how everything is supposed to be, but I can't seem to find anything. The control arm on the transmission has been welded and I am trying to make sure everything is where it needs to be. Thanks for any help, David
  2. 1566 Hand Pump
    Hello, I installed a hand pump on my 1566 and steering doesn't want to work. When you start the tractor, the front wheels will move a little bit, but the steering is very tight. Any thoughts on what the issue could be? Could I have done something wrong with the installation? Is it possible to have crossed some lines? Thanks for any help, David
  3. Steering
    Hello Everyone, I was using my 1566 today pulling a land leveler and I noticed that the steering wheel kept trying to turn to the right. It's been a couple of months since I started the tractor and I don't remember it trying to do that before I parked it. Is something starting to go wrong with the hand pump, or do I have another issue? Both front tires had an equal amount of air pressure and the tires are in good shape. I planted about 500 acres of soybeans with the tractor last year and it always steered great. Thanks for any thoughts, or opinions.
  4. Radiator Value
    Hello Everyone, I have a unique question to ask? Is there any value to an original IH radiator that came out of a 1566? We have 2 1566 tractors on the farm and we ended up replacing both radiators over the last few years. They each developed a very small leak and would loose about 2 gallons of water in a little over a 5-6 hour period of running time. We didn't couldn't find a radiator shop to fix them in a reasonable amount of time, so we replaced them with an aftermarket radiator. My dad is in the processing of cleaning up around the farm and hauling away some unwanted junk and scrap parts. He has about 25 radiators and wants to scrap the IH radiators as well. Is there any value to them for being original IH pieces for the restoration guys? Thanks for your thoughts.
  5. Anti-Freeze Quantity
    Hello Everyone, I am getting ready to change the anti-freeze and coolant filter in my 1566 and my 1086. What is the right amount of anti-freeze to use in those tractors? I am thinking 2 gallons for each one. Is that too much, or not enough. I am in Chesapeake, Va. and we usually don't have an extended amount of freezing temperatures. It can get really cold for a week, or so and then it will warm back up to non-freezing temperatures. Thanks for any thoughts, or opinions. David
  6. International Hough 60 Loader
    The loader has the 6 cylinder Cummins engine.
  7. International Hough 60 Loader
    Hello, I am trying to find some exhaust parts for my dad's International Hough H60 loader and I need some help. On the driver's side, I need the elbow that bolts to the exhaust manifold and then clamped to the muffler. I have looked high and low and I haven't found anything. Does anyone know where I could possibly find that elbow? Thanks for any suggestions. David
  8. T.A. Use
    Hello, I would like to get an opinion from some of the smarter guys on correctly using the T.A. I am planting soybeans with my 1566 using a 15' wide 5400 Soybean Special drill and it has the coulter kart in front . I am planting in freshly turned over soil and I am running in High 1 with the T.A. ahead ( Direct Drive ) . When I get to the end of the field, I push the clutch in, pull the T.A. back, raise the planter up, turn around and take off for the other end. Once I get moving, I let the row marker down and push the T.A. lever ahead. Is it ok to pull the T.A. back while the clutch is pushed in, or should I pull it back while the tractor is still moving? It's working good and I don't want to cause any internal issues from my technique. Thanks for any thoughts, or opinions.
  9. 2 Part Question
    I am getting ready to change the oils and filters on my dad's 5240 tractor and I was wondering what oil I should use in the engine. On the other tractors, 2-1566's and 2-1086's, I use the 30wt oil from Case. My dad is thinking the 5240 should use 15-40 oil. I want to change out the pto in one of the 1566 tractors and replace it with one from a 1086 that was parked due to an engine problem. Will this be a direct swap and will I need to do anything special to make it work? Thanks for any thoughts, or opinions. David
  10. Fuel Line for 1086
    Thanks Travis for your help.
  11. Fuel Line for 1086
    Does anyone know what the part number is for the rubber hose ( Fuel Line ), that runs from the fuel filter to the injection pump? This is for a 1086 and the original hose is starting to fall apart and needs to be replaced. I have looked on the Case-IH website, but I can't seem to find a breakdown showing the rubber fuel line. Thanks for any thoughts, or suggestions.
