ajtel
    563
About ajtel
  • Birthday 04/12/1932
    http://red power
    okla city okla area
    td 14a, 1950
    td 14a, 1950
    td 18a, 1951
    jd, b model, 4 ea
749 profile views
  1. Bucyrus Erie hydraulic cylinders
    type "bucyrus erie hyd cyd " in search block. also send email to be, state what you are needing.
  2. IF DOZER IS NOT USED OFTEN, DISCS WILL STICK TOGETHER. I RUN MY TS18 AND TD 14 ONCE IN AWHILE TO KEEP DISC FROM STICKING.
  3. td14a hyd controls
    i guess its pto drive, pump in front of rad, shaft runs back to crankshaft.
  4. td14a hyd controls
    is there a filter inside hyd oil tank on td 14a?
  5. is there a filter in hyd system td14a? blade slowly goes down with motor running, tank is full of oil. what is cause?
  6. TD18 injection pump issues
    for lil ih mec i can mail you about 50 pages of pics, info, on td18 diesel injection pump. if you want, send email to ajtel16@yahoo. com. no charge to you. pics show disassembled pump,etc. send me your mail address.
  7. about 5 yrs ago, threads w/advice and many pics of inside of pump. what are steps to find, when dont kno posted dates? thanks, ajtel
  8. my td 18 takes 3-5 minutes of grinding before it will kick off on gas. it didnt used to take so long. i check to make susre gas is in carb. any idea as to cause.? i dont grind the starter continually so not to burn the starter. used to start much faster. thanks, ajtel
  9. td18a
    thanks for advice. will have to wait awhile, freezing temps.
  10. td18 flush tranny
    thanks, crawlernut. will try diesel since cheapest to see if cleans. $2.50 gal. kerosene and solvent $9,00 gal.
  11. cheapest product to flush tranny? will need 24 qts. crud on tranny dip stick.dont kno what it is, plus oil is at end of stick. refill 80-90 oil $144, solvent $115, too back cant use water. ha. need advice. thanks ajtel
  12. td18a
    m. diesel td 18 has coil, distributor ajtel
  13. td18a
  14. td18a
    very weak spark trying to start. possible cause? replace coil?
  15. td18a
    possible causes of back 3 cylinders excess white smoke? front 3 cyl ok.
