Redwood
    272
About Redwood
  • Birthday 10/14/1961
  • ICQ
    Monterey CA.
    Work, restoring old things, hiking
    1 - TD-14A
    2 - TD-9A's
446 profile views
  1. Farmalldr, Attached is a photo of TD-9 with Hough loader that I came across at an antique equipment museum here in California. Redwood
  2. Big Crawler Music..
    Gotta love it
  3. I/H TD-6 Engine weight
    According to my IH power unit manual a UD-6 with radiator and clutch is 1765 pounds. Even if you figured 500 lbs for the radiator and misc components you are still at 1265 right where MCC figured. Redwood
  4. TD 14 Emblem, Shift Pattern Decal
    Wthofer, I had the same issue as you with the grill emblem so I made my own. See attached photo. I would be happy to send you the drawing file. Any shop with a water jet or laser can cut it out for you. Redwood
  5. TD-24
    Sounds scary. I guess the old adage "you get what you pay for" holds true.
  6. TD-24
    TD-24 for sale on the Central California coast - cheap - see attached link. Crawler Nut needs this one to add to his fleet. https://slo.craigslist.org/hvo/6192992576.html
  7. Ih Equipment at Santa Margarita.
    Great video......Thanks Redwood
  8. crank shaft dimension D335
    Diameter - 3.6255 - 3.6235 Bearing running clearance .0019 - .0049 Maximum permissible running clearance .007
  9. TD-141 engine stuck
    The engine is supported by the front cross member but it is a pivot point and the crankshaft runs through the middle of it.
  10. TD-141 engine stuck
    Binderdan, I am not familiar with that particular winch but I would say that the inner (closest to tractor) is the forward/ neutral/ reverse lever and the outer is the drum brake. It appears someone welded in a new sprocket ring, grousers are worn down pretty well. You will still need to check the bottom rollers along with the pins and bushings for wear. Redwood
  11. TD-141 engine stuck
    Binderdan, It is not a bearing just the front pivot point for the engine and has nothing to do with the crankshaft/engine not turning. Redwood
  12. Hydraulic pump question
    Tom, Give Associated Tractor a call as they are still the representative / repair facility for Bee Gee pumps. 209-466-3003. Redwood
  13. 48 TD-9 missing parts
    Oldiron, I have a parts TD-9 that probably has what you need. PM me with your needs and I will send you what I have. Redwood
  14. Td91
    Good luck......You will need it.
  15. Td9 block
    Steve, I dropped a parts breakdown of the pump/balancer assembly in the Engine Form that shows all of the parts that you will need to make your engine pump oil. Redwood
