OLD 10-20
    508
About OLD 10-20
  • Birthday 10/14/1960
  • ICQ
    Somewhere in North Dakota
  1. I have a 1965 1100A pickup truck that had an engine swap done before I bought it . Now the owner of the other engine that was in my truck to begin with would like to switch engines back again to original vehicles . I would not have any objection to doing so but wonder since I would be going back to a 266 v8 did cylinder heads on these engines have hardened valve seats ?
  2. Thanks . That's what I found it was . Made the task a lot faster of refilling .
  3. Having heavy frost and loosing power on and off to the electrical lines must have done a number to my frost plug block heater on the 706 . Anyhow its dead quiet and I need to replace it . Draining the engine coolant and refilling it . Is the petcock by the thermostat for the purpose of bleeding air out of the top end of the cooling system ?
  4. I also run a 8430 baler . Belt tension is non adjustable . Snug the tension valve set and go . Power wise you maybe have some heavy swaths or windrows ? I run a CASE 830 on my baler ever since I had the baler . Need to bump the hydraulic valve on the tractor once and a while to keep the belts tight but never noticed it loading the tractor down much .
  5. Hum ,,,, Pay Day ?
  6. And in the early 1980's a lot of Us at FARMALL were watching the first Chrysler Bail-Out REAL close. There was a little talk about IH asking for help like Ioccoca did. I heard it didn't happen because IH only employed 35,000 company wide. Chrysler was about ten times that many then. I wouldnt care if chrysler was ten times larger . Wasnt IH the top agri buisness leader over John Deere ? I dont think international even bothered to ask our government for help .
  7. Rick do the members have to sighn in NOW? cant we just pop in as a guest to check on topics
