W400
    248
About W400
  • ICQ
    Aberdeen Scotland
    all things IH
489 profile views
  1. Found Dad's 1206! Search is Over!
    Thats a neat story
  2. Ih 782
    x2
  3. Negative ground conversion
    More elecrtical questions I understand dynamos dont mind which direction they flow once you flash them after fitting but does it make any difference to regulator coils?
  4. 1936 td 40
    Thanks Jim Poppet valve is lubed and I think good working order to but I think your gas flow check is on the right track will check this. couple of times I opened drain to check for fuel after it quit to make sure it was not dry. Fuel flow was not great have had feed pipe of and glass bowl cleaned good flow to carb.
  5. 1936 td 40
    Any experiences or theries appreciated. Rebuilt everthing on this engine 10 years ago always started 4th crank since it started and ran great back in sept tried it mid Jan wont start somtimes will fire 3 to 8 revolitions then quits valve cover has been off all valves working ok compression feels good on crank handle striped and cleaned carb looked ok changed mag for known working mag old mag also checks out removed intake manifold new gaskets thinking vacum leak all looked good decided timing must have moved?jumped? no looks ok and it is fresh gas or is modern gas so bad it is no use in these old engines? spark plugs cleaned and swaped. thinking it has to be fuel problem am i missing somthing in carb?? Thanks for Now
  6. BTD-6 going back to work at 60
    Id agree with russ in first instance try less water but watch the temp gauge once hot check for bubbles (leaking head gasket a possibility especialy if it was stored with no water) also check to see water is circulating on top of radiator maybe even flush system.water level on these british diesels is generaly just above the core of radiator.
  7. Give and take word game
    assembly hall
  8. IH 276 RestoMod
    Hi R cambell you have a very usable tractor there built in Bradford UK first appeared in 1960 as B275 various fuel upgrades over the years and new tinwork around 1965 turning it into B276 basicaly same tractor built for 20 years ending up in 484 model mechanical parts on this side of pond very available including very well made aftermarket parts. Your tractor has the earlier lift design with no draft control to be honest on these tractors your 3 point is the best much better wheel grip with this system than with the draft control system depth control on this system is controled by the 4" dia knob right front of housing should have an arrow on it and the words deeper. How is the steering can have a bit of slop in steering box easily fixed but time comsuming involves removing dash and fuel tank once there box is very simple there is a race of balls top and bottom of worm gear dirt and water wear these over years easily replaced along with seal on out going shaft fresh gear oil and will steer great yous may be ok if kept under cover but gets neglegted because of time to access.
  9. IH-444 Stuck in reverse
    You probably need to remove the hole gear box lid this will take of both gear selectors around 9 bolts and when you turn it upside down you will see all the selector rails and forks attached to lid gear setup is very simple and you will be able to slide all gears easily to neutral. back to lid having been on a loader the 1st reverse selector is probably well worn if it is really bad a secondhand quality used gear box lid may be the way to go.B275 B414 B434 B444 all the same box.
  10. Rare one up for auction
    !!! perfect IH prices good value.
  11. B 275 Diesel any good
    Great little run about tractors parts are very available slack steering is a common fault fault new steering box around $300 bearings to repair around $80 if your lucky bearings are collapsed and rest is ok but if it has been run along time with water ingress and worn bearings thats no good all parts are very available new wings also, bonnet/hood tin not so available 3 point and pto.
  12. 1968 Mccormick International B-275
    Welcome doin fine Firstly when you had water seperator bowl of and cleaned screen did you open tap and ensure clean fuel coming out of tank sludge when that low can block out let next fuel filter is top left front engine remove top bleed screw on return pipe top of filter.On middle right of engine you should have a lift pump with hand lever pump this till fuel comes out of filter top no air bubbles if lift pump feels like its not working turn engine a 1/4 by hand if it has happened to stop on high lobe of cam it will not pump (very unlikley this will happen) if it still wont pump you need to investigate inside lift pump single screw should remove top and find screen inside clean and replace if it still doesn't work you have open up hand pump around 6 screws to remove top half this will reveal a diaphragm remove top carefully as to not tear diaphragm to remove diaphragm push down and turn a 1/4 under diaphragm you will find 2 non return valves ensure to note there position and direction before removing the one on feed side from tank will be of interest if any sludge got past screen this is where it will choke. once fuel filter is full of clean fuel close top bleed screw and open bleed screw on side of fuel pump 3/8 spanner turn engine over with starter till no air bubbles close bleed screw next slacken a injector pipe at a injector No 3 has best access turn engine till it fires and fuel is leaking from slack injector pipe it will run rough tighten injector pipe should smooth out engine to nice idle.
  13. 1086 clutch problem
    I use a long 1/2" extension bar with a socket on end that fits neatly into pilot bearing then wrap extension bar with insulation tape in the right place for clutch plate keep wraping till clutch is a neat fit, install socket bar and clutch plate install pressure plate and center socket bar as you tighten plate works every time $ for tape going to fit a lot of clutches before it comes to cost of alingment tool
