Rawleigh99
    6,602
About Rawleigh99
  • Birthday 03/25/1962
  • ICQ
    Eastern Virginia
2,279 profile views
  1. Barrett-Jackson Auction
    How much did the Scout sell for?
  2. On a brighter note................
    From Apple and Walmart??? I doubt it! LOL!
  3. Ether (starting fluid) sickness?
    The radiation level may depend on where they were used too!
  4. On a brighter note................
    For some reason the liberals are being very quiet about the results! LOL!
  5. International 500C crawler loader parts
    Email sent.
  6. This POS put law enforcement back 15 years
    If they put him in gen pop at the jail he will be WELL taken care of and won't be grinning after that!!
  7. Bondo
    Do yourself a favor and use a marine waterproof epoxy filler. Bondo sucks and absorbs water. If you want to learn more, google West System Epoxy. They have everything you need. The Six10 epoxy works great, is dispensed using a regular caulking gun and has mixing tubes so that the epoxy comes out the end all mixed up. If you are reproducing molding you can cut the shape into a stiff piece of plastic and screed the epoxy to shape so that there is very little sanding or shaping. You can get it at Ace hardware or off of Amazon. https://www.westsystem.com/specialty-epoxies/six10-thickened-epoxy-adhesive/
  8. flu fires always in the back of my mind
    Probably the steam from the potatoes put it out?? I have also heard of burning aluminum cans to reduce it too. We have a Fisher stove and a SS flue tube down the chimney. Being smooth and straight helps with the buildup as well.
  9. Camphor used in Tool Boxes to Prevent Rust
    Amazon just delivered mine!
  10. Roller Maintenance
    You should post this in the construction forum.
  11. 4-H collectabe Falshlight Help
    https://www.google.com/patents/US2150644
  12. Camphor used in Tool Boxes to Prevent Rust
    https://smile.amazon.com/dp/B01LK880A2/ref=psdc_3737951_t1_B073LN2V2R
  13. 'Tis WARM Again!
    +5 here this morning. Supposed to be cold through Sunday then back to the 40's for next week. That out to be a rotten mess when this snow melts and the ground thaws!
  14. I lost a friend to exactly this scenario about 15 years ago. He was a very seasoned operator who had done this for 30 years and that excavator had a ROPS. A falling tree has tremendous inertia and can easily crush a well built ROPS..
  15. Of course it depends on the size of the trees! Pushing them over gives you a lot more leverage and is easier on the machine generally. You do have to be careful about knocking the top or tree limbs out on yourself. Don'r ram them. Push with the bucket up to apply leverage. You can use the hydraulic down force from the loader to elevated the front of the machine and put great pressure on the tree. If they are bigger trees do some digging first. Be careful not to get high centered on the root ball as the tree falls over.
