axial-flow
    75
About axial-flow
  • Birthday 06/20/1948
    Tx. panhandle
    anything to do with farmalls and nascar
421 profile views
  1. Wheatland Rear Wheel Centers
    The tractor has between 3000 and 3050 hours on it. It was sold new in the Oklahoma panhandle and that's where i got it. I believe the pipe has been banded on tractor since new. Jim
  2. Something you don't see every day...
    Got the I 826 home, original owners son was there when I picked it up. Starts easy and sounds good, shifts like a new tractor. it was nice to get some history on the tractor.We'll wash and polish it and leave it as is. Jim
  3. Happy Birthday ,Axial-flow &Reichow7120
    Thanks for the birthday wishes. Enjoyed red power and seeing old friends and meeting new friends. Looking forward to next years red power roundup and seeing you all again. Hopefully Bitty will be able to make it. On a side note we got home Sunday and Monday we started combining winter wheat. Jim
  4. Over 7 thousand pounds of front weights.
    I don't think so i believe they should have the angle iron hole in them.
  5. 1066 hood bolts
    To fasten the 3 big hood pieces you need 10- 5/16by5/8 in. washer head bolts and 8 373 483 R2 shoulder screw bolts rubber washers and flat washers
  6. Started My 806 L.P. restoration
    Those 301 engines are sleeveless. I'm thinking a crack somewhere in head or block.
  7. Anyone on here near Oakland Iowa?
    That looks like a front mounted cult. bracket. If I remember correctly it was a model 85 cultivator.
  8. 966 Hydro Trans light
    I have a 1066 hydro that I have been working on. I put new wiring harnesses in the tractor and fixed the pressure switches. There are 2 pressure switches on the tractor, one monitors temp. and the one monitors temperature.one of them is on the foot and inch valve assembly and the other one is located behind and to the side of the starter. The light is only supposed to come on when clutch pedal is pushed in or if you have low pressure or high temperatures. Axial-flow
  9. M Hood questions
    I believe it is for a starting tank .Back then the little tank has gas in it and the big tank would have had kerosene or distillate or whatever cheap fuel was available. axial-flow
  10. International 1206 w/odd features.
    This is a late serial no. tractor one of the last 75-80 built my guess it was done at factory to address cooling issues but that's just speculation. Tony, if Brian and I were closer we could do a small show and see some of our Texas tractors and equipment. Jim
  11. 1066 power problem
    Have you had it on a dyno recently? I think that would be a good place to start. Axial-flow
  12. Time to close the book
    I hope things go well for you in the future. Maybe you'll have more time for red power activities. good luck and good health. Jim
  13. Yesterday's Barn Find: IH 75lbs weights
    Tony, The small suitcase wts. are good property to own, but they are the earlier style and don't have the L shaped slot in them to hold them from bouncing off.A careful driver like you won't have that problem though. Jim
  14. The C made front page brochure honors
    Congrats. Hope they have good weather and turnout. Jim
  15. 1066 steering
    If you talk to Long farms he can tell you what parts you need or he can tell you how to fix yours. Jim
