gordon76
    741
About gordon76
  • Birthday 09/13/1957
  • ICQ
    Canton Pa
877 profile views
  1. 300 u hydraulics post for real this time
    the problem is being plumbed for power steering you can't just add a valve the way his is added it causes a hydraulic flow issue. the system is open (no pressure) unless both valves are closed
  2. 300 u hydraulics post for real this time
    I have a small repair/restoration shop and have had a few 300s go thru the shop
  3. 300 u hydraulics post for real this time
    you well only have to get 1 ported cover 364878R1 (it takes 2 but you already have one on the rear valve) Yes the hydraulic system well have to be drained. There is not a kit available to rebuild the valve, find parts list here https://partstore.caseih.com/us/parts-search.html?csid=b562a8b7770c3291163092d461a8eb06&sl=EN&currency=#epc::mr59117ar871746 I would get it plumb correctly before rebuilding the valve or replacing the pump. There are also 6 o rings you well need #75285739. Some of the parts are available Case IH here https://partstore.caseih.com/us/parts-search.html?csid=b562a8b7770c3291163092d461a8eb06&sl=EN&currency=#epc::mr59117ar948813bi1082485-18 The ported cover well be a used part
  4. 300 u hydraulics post for real this time
    power steering was not standard on the 300 it was an option from IH. it looks like everything is plumbed correctly for power steering and fast hitch. the problem is the valve the loader is hooked to that is not plumbed correctly. what you well need is cover # 364878R1, tube # 364888R11,tee # 9410119 , plug # 364880R1 the plug goes in the 1/2" pressure port between the valve and the reservoir. you well have to remove the elbow from the cover on the rear valve and install a tee then hook the new tube between the front and rear valve covers. should look like the drawing when finished. Please excuse my drawing skills
  5. 300 u hydraulics post for real this time
    the leak on the foot rest is from the pipe fittings IH spool valves are not pipe thread they use a oring fitting
  6. 300 u hydraulics post for real this time
    the issue you are having with the hydraulics is because of the added power steering. The loader spool valve is not plumbed properly and is deadheading the system. that's why the power steering is consistent and the rest of the hydraulics are not. your system is missing #18 supply line and 21 plug
  7. My new old transit level
    they are spare plumb bob points https://www.pdf-archive.com/2016/05/09/david-white-lt-8300-manual/david-white-lt-8300-manual.pdf
  8. Birthday List has several today
    Thank you
  9. Farmall Parts
    worked for me also if you create an account you can bookmark the manuals you use the most. A thru M are on pages 1 and 2 starting at the bottom of page 1
  10. Farmall Parts
    have not been using Messicks, I use the CaseIH online parts store
  11. part #s for single stage clutch pressure plate 635110R91 clutch plate 635112R91 bearing 365865R91
  12. Farmall Parts
    it won't bring up A, C, H, or M if you type Farmall on this site https://partstore.caseih.com/us/index.php?target=epc_manuals_detail&sl=EN#epc::model_find
  13. Farmall Parts
    now if i could just figure out what they did with A, B, C
  14. Farmall Parts
    Farmall md brings it up
