tommyw-5088
    7,181
About tommyw-5088
  • Birthday 01/31/1967
  • ICQ
  • Yahoo
    twwhowdy
    trying to educate people on how bad liberals are .
1,569 profile views
  1. The Home Of Misfit Toys
    My 43 runs .
  2. Salvage values
    Salvage yard has to steal it from you . Been my experience .
  3. 4366 trans lube
    Where is the fill plug for the trans system ? Mine has a hose plumbed up to the normal fill plug location on a truck transmission . Thanks for the replies everyone
  4. DT466 Truck engine transplants
    4366 has a truck engine in it .
  5. 4366 trans lube
    Thanks everyone ,It seems to have some type of lube pump driven off the side of the transmission . The line feeds the front main pump , its really odd . what does the trans lube pump actually do ? The dump from the hydraulic levers is dumping on top of the pinion . Is this the updated pressure lube pinion ? Oil is clearly going in and out o the transmission.
  6. 4366 trans lube
    The 4366 appears to have been updated to the 86 series lube system . Trans /diff/ transfer case all tied together . How can I add a pressure gage to monitor the pressure , and or a pressure switch somewhere to keep an eye on it . It has the sight glass in the front diff ,I think it could have been updated to pressure lube on the front diff . Tractor has about 10,000 hours , but many parts are new or rebuilt .
  7. 4586 -what are they worth
    With trucking included , have 4250$ in my 4366 . real solid tractor 20.8 singles .
  8. More surgery
    hope it all goes well .
  9. 5488 blow by
    Got our 5088 new -5100 hours now . Has always had more blowby than an 86 series -imo
  10. 4366 front diff
    Is the front diff pressure lubed along with the transfer case . Are they the hydraulic resivor ?
  11. 496 non-rockflex discs
    No where near enough tractor for a 19 foot . Got a 20 and it will work a weighed , dualed 5088 plenty if any moisture .
  12. 886 hung in 2 gears ?
    What is worn out , 4200 hours .
  13. New CaseIH 300
    Buy 4 of boxcar magnums for the same $$
  14. 5288 fuel plunger
    plastic line to tank stopped up . Blow it out .
  15. New Lease On Life For My 5088
    Great job , IM glad someone likes the 88 series . Wish Mike would make a reverse door kit and sell it ....HINT !!
