TW7110
    118
About TW7110
  • ICQ
    CENTRAL MN
370 profile views
  1. How dry is it in your area?
    It was a late wet spring everything was still looking pretty good, but we only got a 1/2" rain in July and its going backwards fast. South of me near Richmond corn is knee high for the second time.
  2. Expanded the shop....
    One thing about having a dirty shop is it is like Christmas all over when you clean.
  3. Hydralic thumb releif
    X2, Nothing good is going to happen if the thumb relief is to high.
  4. Moly grease- - - - - how many still using it??
    Use it on all pins and bushings. Find it keeps a grease film a lot longer.
  5. I just saw this on Avsig:
    This topic was on Agra-Talk a few months ago. Deere was the biggest push behind it, but there were others. They used safety as a big factor also, but it all about lining there pockets. It could back fire on them in a big way. I've talked to a lot of loyal John Deere guys in the last year and they are not as loyal as they once were. They will tell you the equipment isn't as good as it once was and they are tried of working with large multi location dealers. Some have said the last tractors Deere made were the 55 series.
  6. Bobcat regular maintence costs
    I was a shop foreman for a large contractor ( at one time had 19 skid loaders ) the track machines can do a lot more work but they have double the operating costs.
  7. 666 zenith carb
    Yup. I'll PM my phone number
  8. 666 zenith carb
    Have you had this tractor for awhile? If not did it come from the St Martin, Albany area.
  9. CIH 5250 real value
    Those decals are not original, they didn't come with that decal on till S.N.1046511. That machine is 1033130.
  10. Quality power products
    A&I Products has them. A-HXE46027 std A-H208431 kevlar TSC Store #2111 17020 Smokey Point Blvd, Ste A Arlington, WA 98223 360-653-2123 http://www.tractorsupply.com Yesterday s Tractor 751 Commerce Loop Port Townsend, WA 98368 800-853-2651 http://www.yesterdaystractors.com C and P Agriculture Repair LLC 19422 Tellesbo Ln. Conway, WA 98238 360-661-0270 TSC Store #2057 32165 State Route 20, Unit 1 Oak Harbor, WA 98277 360-240-1400 http://www.tractorsupply.com
  11. Ji case ?
    Except pto.
  12. Ji case ?
    That would be correct.
  13. 5488 Repair
    I have heard nothing but good about that CVT transmission.
  14. 1086 reman AC compressors?
    X2
  15. off color question
    There are two bleed screws on the pump housing that need to be bled out, first there is one 3/4 way up pump housing and then the one on the top cover. Loosen and pump transfer pump on till you get stream of fuel.
