czech
    1,691
About czech
  • Birthday 01/21/1949
  • ICQ
    Pearland, Texas
    Trap & Skeet shooting. Rifle bench rest shooting.
1,287 profile views
  1. DV-550 vs 9.0 pistons
    Can you use pistons from a 9.0 in a 550?
  2. Td-14 primer pump?
    Is there supposed to be a primer pump for the gasoline side?
  3. Information on this engine wanted..
    The UD-16 or UD-525 is not the same engine that the TD-18 use. This engine was used as power units for various makes of machinery. It will not just bolt into a TD-18 without modifications.
  4. 392 V8 engines
    Where can I find the weight & dimensions of the 392 V8 engine?
  5. 392 V8 Dimensions & Weight
    Does any one know the weight & dimensions of the IH 392 V8. Where can I find them?
  6. Going look at a 1970 Pick up
    Keep it all IH. No Cummins, Ford, chevy engines.
  7. I'm jealous! Great combo!
  8. Roosa pump question
    Did you bleed the fuel system including the Roosa Master of air in system? There should be a return line fitting on top of the pump. This fitting has a little glass ball in it that restricts fuel flow. If it has trash in it the pump will not pump.
  9. 77 Sunset Street Hot Rod
    Does anyone know what engine was in the Hot Rod driven by "Kookie" in the TV series 77 Sunset Strip?
  10. There is a Cub Cadet on Facebook advertised as having an M & W 9 speed transmission & a PTO. Is this factory?
  11. M&W 9 speed with PTO
  12. I saw a photo of a TD-25 cable blade crawler that had 3 top idlers for the tracks. Was this a special order? The frame looked a lot longer than what I remember.
  13. DV-550 V8 Diesel
    Anyone know when the engine fuel injection pump was changed from a Holley to a Bosch pump? In 1968 I worked on a 550 that had a Holley pump. It was out of a Fleetstar 1950.
  14. DV-550 Diesel Engine
    Does anyone know when the injection pump use on the DV-550 was changed from a Holley to a Bosch?
  15. DV-550 Diesel Engine
    Does anyone know when the diesel fuel injection pump was changed from a Holley to a Bosch?
