bmk
    61
About bmk
  • Birthday 12/19/1962
    VINA AL
211 profile views
  1. 826 Engine Swap
    The guy that owned the 1256 died, i traded for from his son. He said it had some hydralic leaks was the only thing he knew was wrong with it when his dad died. The PTO assembly has been taken out and put in a 1466 they had. It will need a PTO assembly which i am looking for while i try to get arrangements made to move the tractor. Matt, that was the main reason i asked here about the difference. I dont have a whole lot tied up in either tractor at the present time. I had already found that the clutches were different in size. Most of the time I tend to fix whats on a machine instead of changing to something else anyway. If i dont find a PTO unit , I have been thinking i could possiblely take the PTO out of the 826 and put in the 1256 to see what happens if dont find one by the time i get it home.
  2. 826 Engine Swap
    Thanks guys for the replys. I have never got to use either of these tractors, so im not leaning toward one over the other. In my mind, i thank the hydro would be great for hay and loader chores. The 826 was not running when i traded for it, and i seen the 1256 being used. When i can afford it, i want to completely restore the 826. When i get a chance to pick up the 1256, i may use it like it is and not even consider the swap. Hopefully i can get the 1256 home within the next week or so then i can decide which way i want to go. I know ill enjoy using either one because they were made to use and keep lasting with just a little attention. There used to be a dealer close back when these tractors where new and a lot of IH stuff in this area. Now the nearest dealer is about an hour and half drive. Eason, there is stil a few old cotton pickers around, but scrap yards got many of them as well as old tractors like these a couple years back, so there are getting harder to find. If you happen to run across one, people dont want to get rid of them or they want the price of an fully operating machine. Thanks again for the replies, I knew i could get some good feed back here. Ill post when i decide what im gone to do.
  3. 826 Engine Swap
    Thats a good looking 1256
  4. 826 Engine Swap
    Lars, your correct, I dont really need that much power to do either. I got a 7 wheel disk mower and a 10 wheel v-rake. We normally use either a gas 504 farmall, a 3910 Ford, or a 35 hp Kubato to do the raking. My plan would be to put the mower on that tractor and not take it off till season is over. I had a 1086 that i used till i traded for a CX90 Caseinternational where i would have a cab to get out of the hay dust. The 1086 was a longer wheelbase and rode much better than the CX. Both these tractors are open platform tractors. I hope to be able to restore the 826 back to orginal when i can afford it.The 358 will have to be totally rebuilt thats in the 826.
  5. 826 Engine Swap
    Tractor would be used for cutting or raking hay.
  6. 826 Engine Swap
    I have a 826 Hydro with a 358 engine needing a overhaul. I recently traded for a 1256 that was suppose to run. Was wondering what would have to be changed to put the engine out of the 1256 into the 826 Hydro. I understand im going to an older and smaller engine, but needing another tractor for hay season. Hoping to do a complete restoration on the 826 when i can afford it. Both tractors are complete. Thanks for any help. I have not picked up the 1256, so i have not looked at them side by side to see any differences.Im just looking any possible options. I know this group of Ih folks already has the answers. Thanks again.
  7. CX 100 won't start
    I have got a CX90, had starting problem same as you, turned out to be a relay located just just above the starter .
  8. 1086 lower hitch seals
    Thanks, thats the only part of one of these tractor i hadnt worked on. Its leaking pretty bad. Dont know the history of the tractor, was recently bought.
  9. 1086 lower hitch seals
    How much trouble is it to change the seals and bushings on the lower shaft that holds the lift arms? I was told the bushings have to be pressed out and new ones presed back in. Its leaking oil where the shaft comes out the side of the rear end housing.
  10. 5410JD Brakes
    CIHTECH, thats what i had to put in my CX90 CI when my left brake completely quit. Thanks for the information.
  11. 5410JD Brakes
    Its not the same as a clutch brake, it does it with the clutch pressed down just enough to stop the tractor just like where a parking brake was used and not totally released or pushed off.
  12. 5410JD Brakes
    I had a guy brought a 5410 by my shop for a clutch adjustment. When you push the clutch in, the brakes were hanging enough to stop the tractor without you putting your foot on brakes. Not being familiar with that series tractor, I checked what little i knew to check. When he came back to get the tractor, he said it had done that ever since he bought it new, said the JD dealer said it suppose to do that. Tractor has a quite a few hours on it. Has anyone else had any dealings with this, or does he have something in his brakes thats not working correct.. The tractor has a park in the transmission. Feels just like a parking brake on thats not tight enough to hold the tractor. Thanks for any feedback.
  13. 826 Serial Number Registry
    SN 007989 826 Hydro, diesel, 3-point hitch, waiting on engine overhaul. Vina Al
  14. CX90 Brakes
    My CX90 will lose the brake on the left side and still have a full pedal on the right. I replaced the kit in the cylinder about a month ago , which i didnt see anything wrong with what i replaced. Started doing it again this week. Any help would be appreciated.
  15. Case 2290
    The cables are working. I looked under the bottom where the controls are but wasnt sure what suppose to do what. I was guessing that was where my problem possibly was at. I will look at it again. Thanks
