ccrider
    7
About ccrider
  1. International 250 Loader
    Do you have the link to the video?
  2. International 250 Loader
    Thanks for the response, mine has yhe strait six with a turbo. I do appriciate the heads up. Right now i am fighting cooling issues, lots of rust is in the system did the dishwasher flush, tried prestone and evaporrust neither has worked to well. Going to get another flush and try again.
  3. International 250 Loader
    Thanks that did the trick, it took all the load off the spring once the fluid leaked our of cylinder.
  4. International 250 Loader
    Thanks for the info, trying to get it back in good shape. I am using it on my property to build levies on my fields for duck hunting lease. I haven't used it yet trying to work major bugs out first. Here was the radiator pre flushing, was a major job.
  5. International 250 Loader
    More pictures
  6. Hello I am new and looking for some information on a track loader I got. I have been doing some work fixing a few things on the unit, staring with filter changes and flushing the cooling system but I don't have allot of information on the unit as far as year. It has a drott 6 and one blade and runs good but gas some hydraulic leaks on one of the ram cylinders and a spring and cylinder next to the seat (is the spring under a load or can it be unbolted without anything special as to rebuild the cylinder? Here is the info on the tags 250 loader L250P 4844 2510
  7. Hello I am new and looking for some information on a track loader I got. I have been doing some work fixing a few things on the unit, staring with filter changes and flushing the cooling system and replaced bottom radiator 3 inch hose but I don't have allot of information on the unit as far as year. It has a drott 6 and one blade and runs good but has some hydraulic leaks on one of the ram cylinders and a spring and cylinder next to the seat (is the spring under a load or can it be unbolted without anything special as to rebuild the cylinder? It also drips diesel somewhere at the bottom of injector pump. Here is the info on the tags 250 loader L250P 4844 2510
