A_Joseph_PE
    9
About A_Joseph_PE
  1. IH464 Starting Issue
    THANKs guys. I have some frayed wires going to the started solenoid that may be the culprit. I am going to try to replace each individually to see if it fixes the issue do they make complete harnesses for these older machines? Thanks again
  2. IH464 Starting Issue
    I seem to have an issue starting my tractor. New battery. When I turn the key it just "clicks" a few times then it will turnover. Most times I can't get it to start fairly easily. If it runs dry and just keeps turning over and I turn the key off (say after 10 seconds of turning over and no start) if I turn the key directly after I get nothing no "click" I wait a few minutes (say 2min) then it will usually "click" a few times and start to turn over again what is with the "click" before it turns over ??
  3. Will I lose all of my hydraulic fluid
    Thanks.
  4. Will I lose all of my hydraulic fluid
    Sorry. I'm new to tractors. I have tried to keep individual questions separate and forgot to tell y'all the model. Yes, it is the 464.
  5. Will I lose all of my hydraulic fluid
    If I change my hydraulic filter will all of my fluid drain out? Read someplace that it wouldn't. But I would like confirmation. Thanks.
  6. IH2250 Loader
    Thanks.
  7. IH2250 Loader
    I have an ih464 with a quick attach loader. Loader has been off for a couple years. Needs one hose replaced, but Any advice on what to look for before I try to install it on tractor? looks like it has two 1" o.d. And two 3/4" of lines. How do I know what line goes where on the control attachment? Thanks
  8. Ih464 hydraulic issue
    Is seems that my three point hitch will only move if the draft is on mid point of the levers movement? Also, if I leave it in the up position it will fall over night? Im gonna change filter today but any thoughts, thanks.
  9. Ih464 hydraulic issue
