JessePeden
    12
About JessePeden
  • Birthday 12/06/1982
    Sunbury/Mount Vernon Ohio
    Farming grain and livestock my wife and kids
154 profile views
  1. Is all DEF fluid the same
    We started leasing a 17 magnum 200 and are getting ready to start hopefully spreading chicken litter soon, my question is can I buy Def somewhere other than dealer is it all pretty much the same I just don’t want to mess the warranty up or something. Info appreciated
  2. Is all DEF fluid the same
  3. 20’-24’ disk thoughts
    Do you have a harrow or anything on the 7300
  4. 20’-24’ disk thoughts
    Is it 7 or 9” spacing?? How big of one do you have
  5. IH 1460 combine Hydrostatic Cable Replacement
    It has a couple clamps that hold it up out of the way inside by rotor the hard spots are small holes at back of cab and should have rubber bushing/ grommet in cab wall and wall of seperator you can reach inside seperator from left side of machine and feel your way to top of cylinder and your throttle cable will be there also it basically follows same path I had to stand on 4’ step laddder to reach top of cylinder cause I’m too short
  6. IH 1460 combine Hydrostatic Cable Replacement
    Been awhile with a 1460 but I think if you take the cover off on outside of cab opposite of door (outside wall where controls are) you can unhook from lever and it goes through the cab and routes above the cylinder and back out to the pump back by the engine I did a throttle cable when we had ours it was not terrible but took some time it runs basically the the same route if I’m not mistaken
  7. 20’-24’ disk thoughts
    Is it 7 or 9” spacing what size magnum is yours thanks just really get into higher horsepower we went from a 4020 and 4430 to the two we have now and I can hook all of it together and pull at once now😉😎
  8. 20’-24’ disk thoughts
    What model is this
  9. 20’-24’ disk thoughts
    I appreciate all the info is on the chisel plows we bought a Glencoe nine shanks soil saver, now we’re looking for a 24’or 25 foot diskthoughts on the best one want to get to mainly discount corn stocks in disc in chicken litter we have a soil finisher with a rolling Harrow to finish fields with will be pulling with the same tractors new magnum 200 and 4840 Deere I think everyone ahead of time for all the wisdom out there
  10. Best disk chisel for the money
    Have a new magnum 200 and 4840 Deere want a 9 or 11 disk chisel to help in high traffic areas and end rows good older (cheap one)😉 who make a good older chisel??
  11. Custom combining rates
    We have a neighbor that’s needs 100 acres each of beans and corn harvested he is hauling to bins I just need our 1666 and grain cart what are going rates?? He said $30-35 per acre seems high but I know I’m behind times😑
