1967ihtruck
    45
About 1967ihtruck
  1. Buying another truck
    I have no choice but to drive the freeway part of the way and that is the part that worries me
  2. Buying another truck
    From what the person says it is I am gonna fly up there ad I a trying to determine if I will drive it or have it hauled back
  3. Buying another truck
    I am thinking about buying a 1971 Chevy 3/4 ton truck but is about 1000 miles away and I was wondering if it would be a good idea to drive it home it has a 4 speed manual trans and a 350 engine I was wondering if it would run comfortablely down the freeway
  4. IH 886 with German diesel
    We have an original 886 with German diesal and it will pull like a mule not turbo and the fuel pump hasn't been turned up and is still at factory settings. My dad said when he was young they used t as a dozer pushing trees over and clearing land. Like they said earlier it will break traction before bogging down and uses no oil and is easy on the fuel.
  5. 1486 tach not working
    My dad has an original style tach on his 986 and it does not work at all and I was wondering what it could be. We also have a 1086 with a tach with all the fancy buttons ad it gives a false reading all the time too it lights up but it just gives a false reading
  6. Shifter
    It is a three speed on the column
  7. Shifter
    I broke my shifter linkage adjuster and I can't find another one where can I find one
  8. 1967 ih 1100b
    The right side is a little dented up because my grandpa roped it one time but it is pretty good over all
  9. 1967 ih 1100b
    The other day my grandmas found the original line setting ticket, sale paper, and operators manul for my truck I thought that was pretty cool
  10. Truck won't start
    What can I do about a sticky distributed advance
  11. Truck won't start
    Went out this morning and it wasn't doing that but it wasn't doing that but i adjusted the distributor and it runs smoother but the toms go up and down not all the way up but up and then down and if I rev it up it revs but it still goes up and down what is it
  12. Truck won't start
    I got the truck to run but it idles really rough and when I try to accelerate it it dies. It has a new fuel pump new plugs and plug wires. All the valves are opening and closing right. Ps if u didn't read earlier up it is a 1967 304
  13. Cams
    Ok do y'all think a 4 barrel would be a good swap from the factory two barrel and if so what size or kind
  14. Cams
    The truck is a 1964 Chevy c60 which is a two ton the max gvw is 19500 the gear ratio is either 9.97 to 1 or 8.87 to 1 on the low side since it is a two speed rear end and I am not sure about the high side. The trans is a 4 speed and it original. The 350 engine replaced the original 292. The reason I thinking about the engine on this truck is because we haul about thirteen bales of 4 by 6 bales and the motor is not quite enough to pull the load down the road and when you get to going up much of a hill going down the road or pulling out on the road it is pretty slow and I was just wanting to give it a little extra power to help it pull the load
  15. Cams
    What is most important in picking a cam and making the most hp lift or duration and what it the best for a 350/305 Chevy I know this is an Ih forum but I just thought I would ask
