Eric L Taylor
    12
About Eric L Taylor
  1. model 10 vs model 510 end wheel drill.
    Thank
  2. model 10 vs model 510 end wheel drill.
    Do You have a link?
  3. repowering a 3388 from a 715 combine.
    North Central Kansas we usually have 7 to 30 up to 50 days -14F or colder each winter. I have seen it go from 60 deg to chopping 1 inch thick ice on ponds in 10 hrs. Then cutting ice with a 16 inch chainsaw 7 days later. Almost not getting through it.
  4. repowering a 3388 from a 715 combine.
    The clutch is attached to the engine flywheel by 2 u joints and a short shaft.
  5. repowering a 3388 from a 715 combine.
    By 2 bails I mean carrying 2 at home 2 more 5 miles away and 2 more 10 miles Away to feed cows at each location. All i Wanted to know is " are the bolt patterns the same?" Aparently the answer is NO. Thank
  6. repowering a 3388 from a 715 combine.
    I have a 3388, 3588, 1066 tractors, 715 combine, 1460 combine, JD 4320,JD 4430, MM jet star tractors. Yes my 3388 loader & 3588 (2+2)s no loader look like the pictures. I want a gas engine so I don't have to plug in the diesel when it is very cold. I am just using it to feed cows 2 or more round bails of hay. Possibly a Vermeer Bale processor. The 3388 has a loader but the injector pump ran away and exploded the crank through the block.
  7. repowering a 3388 from a 715 combine.
    Got a model number for the
  8. 3309/3312 disk swather
    3309 your book doesn't have both sets of info?
  9. repowering a 3388 from a 715 combine.
    I just need a tractor with a loader (which is already installed) to feed cows. I already have the 303 also.
  10. repowering a 3388 from a 715 combine.
    Will 303 gas bolt in place of the diesel in a 3388?
  11. model 10 vs model 510 end wheel drill.
    Will the slow speed sprockets from a model 510 fit the model 10 to slow the seeding rate?
  12. 3309/3312 disk swather
    Looking for info on a 3309/3312 disk Swather. Is anyone willing to share info from operators manual, parts manual or knowledge on oil types, fill levels/locations and quantities. I purchased the New Idea version but haven't found the books from NI, IH or even Heston.
