timh
    5
About timh
  1. wd 9 injector pump
    Yes that is the seal I need! Do you happen to know the part # of the seal you used?
  2. wd 9 injector pump
    Looking for the seal that goes on the drive end of pump on wd9 . Any suggestions or part number would be great
  3. crank shaft dimension D335
    Thank you!
  4. crank shaft dimension D335
    Can some one tell me what the size is of a standard rod journal is on the D335 ??? Out of 45 wd9
  5. id 9 crankshaft
    I have an id 9 with crankshaft casting number 50978 d. What I need to know is if a crank with part number 50977 d will interchange .whats the difference in the two?
