stronger800
    390
Everything posted by stronger800
  1. Hello. I'm new here. Don't laugh, but I'm looking mostly for a place to buy replacement weatherstripping to go between the hood and cab, and around the doors on '76 delux/factory cabs. Parts diagrams say to "source locally", but my ability to "source anything locally" hasnt been going very well. Any tips? Thank you in advance.
  2. 1206 w/ 30 inch rubber
    X2
  3. Tractor pulling air shut off question
    I'm thinking that would break something. Maybe the guillotine, maybe the plumbing, or the wheel. I'm not a puller though, and have no experience. It just seems physically wrong to go on that side.
  4. High Hours - Low Hours - How Many Hours...
    1,500 hr 12,000hr 14-15k hr. (Tach worked but hr meter was broken for a while when I was a kid.) On the three above. the 856 below I just found with 7000 on it, but the tach had been replaced and only was showing 2k on that one. Original tach broke at 5100. Owner had notes. I found a 7300hr tach, and put it back in. Tractor looks to be a 7300hr tractor. Matches the condition of our 10-14k hr ones, or I wouldn't have brought it home. Most "low hr" tractors I've gone to look at, turned out to be a nice long ride to just get coffee.
  5. Welcome to the forum! Nice looking tractor. I'm fairly new here too, but I suspect these guys are going to tell you to look,for original IH fenders, mounts and steps.
  6. Cool. You'll need bigger rims for the 20.8s, but that's probably good because you can just unbolt yours and sell them as a set. Halfway decent tires sell fast, given the prices on used ones
  7. Repainting metal 101?
    I love ford 5000's. And ford blue is about the easiest color to work with too. I too would avoid sandblasting. Why disturb that heavy factory primer? Manually Sand it smooth. Even Smoother if you are going for perfection.
  8. 756 rear end noise
    I have no idea, or understanding of what's really in the rear of these things, but I can't be the only one who is surprised at the magnitude of that noise. That's a good clunk right there. What is it guys?
  9. New to me 1066 Hi Clear
    Looking good. Where did you get the battery covers? If aftermarket, how well do they fit? I need a set
  10. 656 pto slippage
    Pto clutches would not ratchet, and they really only slip, about one time, then they just kinda stop, right? That's my experience anyway. But I think I probably had a little more load on them than what this 656 is seeing.
  11. I always like that there nf pic of yours too. Neighbor always use to put one under his 1206 for pulling when I was a kid. Thanks, (They're mostly my fathers....I just try to keep them nice). There's another 1066 here someplace that keeps getting missed in the pics, here it is on the right. The one that use to have the white delux cab on it. 11 or 12k hrs on that one too. 856 is a little wet in that pic, had pulled it outside to adjust new/used throttle linkage. Original one had a adjuster nut tac welded in place.
  12. Aftermarket battery cover 856
    Are the $20 ones I see online just ridiculously crappy? Are There some that are better than others? I have to think they are probably all stamped cheaply in the same place. Anybody have a nice, but not perfect or anything, original set that's good enough for a working tractor? Thanks
  13. International 1066 Tractor rim Identification
    7and8and1456, Nicely done with the pics!
  14. International 1066 Tractor rim Identification
    They look terrible, but they are also tough bolts, and bolts aren't cheap. I think I'd still try soaking them for a bit, days, and then heating the nuts with a torch before I just torched or snapped them off. Maybe the are rusted thin on the back sides. He'll have to get one off and look.
  15. International 1066 Tractor rim Identification
    The bolts in your 2nd and 6th pictures. They bolt to cast iron tapered rim clamp pieces (see them in third pic) Stare at them, after washing, and you will see that two of them look slightly different than the other ten. Take note of them. They are important when placing the new rim.
  16. International 1066 Tractor rim Identification
    I believe most of the aftermarket rims now come with a few different spacing options built into them, you just use the ones that match your bolt pattern. The rims are only about $300 last a knew. I've purchased two within the last three rears, and a handfull over the years. They are excellent quality, and all you need. I'm surprised the dealership that quoted you the $695 did not offer the more economical alternative. Dealers here, usually stock the aftermarket ones. You're going to want to pressure wash that and then get the bolts all soaking with penetrating oil. Who ever mounts your tire would probably chsnge the rim for you too, but it's not that hard to do yourself. Either way, get them soaking.
  17. Nice sight of eye candy on this 5288
    I'm still fairly new here...... What's a "scratchie"? Tires look "new" to me. If it was priced in the mid 20's, here in NY, I'd think,it would sell fast
  18. 756 Hydraulic Flush
    Get under it and look up. There are 2. Or three. I should know....three i believe. One in the front (trans), another one in the trans just behind it, and a third one in the rear end housing back toward the drawbar front attachment. That's the lowest and where your most volume will come from. They are all in line, right down the center of the tractor. Lift the fill/dipstick out to give it a good vent while draining.
  19. 1966 706 D310 Pressure Sensor Questions
    And they both operate by forming a Ground, correct? Meaning there is power to one post on that filter gauge and also power to the red hyd light ( it's in the fuel/water temp gauge, the red light on the left center of the gauge, and the Amp/charge light us in the same spot on the right) and they become activated when the sensors in question complete the Ground circuit. Basically, if you want the gauge and the light to work, you run 12v power to them off the key switch circuit, and ground them through the corresponding sensor. I think. Somebody will correct me if I'm wrong, then I'll know.
  20. "I`ll be honest with you"
    Buyer beware. I try to be so honest and give so much info, that buyers probably think I'm lying anyway. Then I let them walk around and look other things over. Doesn't take long until they realize that I have just a touch of OCD.
  21. 1066 Christmas cheer
    I will not sandblast either. But I use to go through a lot of 3m scotchbrite pads, on the cast parts, after steam cleaning. Body sander on the flat parts and sheet metal. I'll look into that paint. Wasn't aware of it. Thanks
  22. Thanks. 7k hr 856 added in a few months ago. M+W on it. Never plan to take a pic, just snap things randomly. Could have moved those jugs, previous owner said the fuel in it was five years old.
  23. 1066 Christmas cheer
    And the paint stripper leaves an even surface for primer? Or do you sand blast after that? Forgive my ignorance. I thought that looked like sand blasting. Interested in the urethane too. I have not painted in years, but we use to use primer sealer then enamel and a shot of clear. I want to get back into it someday.
  24. 1066 Christmas cheer
    Very nice
