Stevetd9
    35
About Stevetd9
  1. OK thanks I'll have a look mine, is just blank on the can no gears, I don't want to pull my motor down, I can get the oil pipe mainly after the sleeve that slides into the block
  2. Hi everyone I'm chasing engine oil pump parts for TD 91 b350 engine, the parts photo I need number 1,2,3,4,5 , any help would be appreciated as I'm in Australia and having trouble sourcing what I need
  3. Hi George what do you mean by the sticky at the top of the forum? Where do I look to search for parts?
  4. Thanks is there any where in USA where I can source the parts I need as I'm in Australia
  5. OK no worry's thanks for all your help
  6. OK cheers my dipstick bit different but is all good, just got to find parts now, would you ever sell the bits I neef off that motor if I can't find parts in Australia??
  7. Just need to find parts now
  8. Thanks heaps this solves it ,just need to
  9. OK thanks heaps I'll have a look
  10. Also how does it atach up into the block that tube? As the hole is bigger then that tube
  11. That's abig help thankyou,wat is that other straight pipe is that just a dipstick tube??
  12. Yes I have no oil pressure cos all the oil is dumping out where the oil transfer pipe goes, Im obviously missing parts, am I sposed to have that small high pressure line that goes to the galleries plus the bigger transfer line?
  13. I haven't moved any bolts so there is basically 2 oil pumps in motor?
  14. Does my pump setup also look correct??
  15. Here is a picture of the hole, yes mine has the pump running off crank with a small oil line running to oil galleries, can that old distributor hole be plugged like the top??
