maulem4220
    4
About maulem4220
  1. 125 e trans leak
    Where is this 125 located?
  2. 125E no reverse
    Update on 1979 125E track loader, had mechanic take a look today & check pressures for diagnosing. Pressures were good & he suspects 2nd hook seal ring on the end of the directional shaft broken. Looks like will have to pull the engine to get the transmission out for repair. Hoping all parts are available? Anybody been into their powershift trans before? Any idea of how many hours to do a job like this? Any advise? m4220
  3. 125E no reverse
    Hi, new to the forum,also posted in IH General Purchased a 125e powershift trackloader a couple of months ago, all has been working well until yesterday. Was working on picking up a log to put on the mill. Went to shift into reverse & tractor doesn't move. All the forward gears work fine. All gauges in the green, can see the gauge flinch when shifting into reverse the same as it does in forward. Suspecting a stuck spool valve the range valve? Any suggestions for diagnoses? m4220
  4. 125E no reverse
    Hi, Purchased a 125e powershift trackloader a couple of months ago, all has been working well until yesterday. Was working on picking up a log to put on the mill. Went to shift into reverse & tractor doesn't move. All the forward gears work fine. All gauges in the green, can see the gauge flinch when shifting into reverse the same as it does in forward. Suspecting a stuck spool valve the range valve? Any suggestions for diagnoses? m4220
