sd186man
    22
About sd186man
  • Birthday 08/21/1973
    Lemmon,SD
522 profile views
  1. 966 MFWD INFO
    Does a truck axle have planetary hubs?
  2. 86 and 88 series foot throttle
    Please tell me someone is getting a kit ready to sell. Farmshow magazine had an article in 1982 that kelderman mfg was selling a kit, but emailing them a few years ago got no response
  3. Wisdom of buying an Elwood axle to farm with?
    This 1486 is a strong loader tractor, turn radius isn't bad at all, we use it year around hauling hay, feeding, seeding, hauling manure, cutting hay, and anything any other tractor does.
  4. 2350 loader on 86 series?
    All I can think of is it would build up heat in the oil
  5. 2350 loader on 86 series?
    Really? All the foot and inch pedal does is dump oil pressure, you can do that forever with no damage. I shouldn't have to explain how slipping a dry clutch turns out
  6. Correct front wheels
    Thanks George 2, I think that answers my question, I wasn't sure if my hubs work with the hub pilot wheels and flange head bolts. Messick's lists the magnum wheel bolts for $17.49 each. Ouch! Does anybody know of a cheaper source?
  7. Correct front wheels
    These wheels have stood up to heavy loader work so far, but it looks like it puts a lot of torque on the wheel centers and bolts. The tires are 14Lx16.1
  8. Correct front wheels
    When I changed my 5288 to the hi capacity front axle the seller told the wheels are the same and didn't send me any. My wheels fit but the offset isn't right. CIH has the same part number for the wheel for both axles and magnums but the magnum uses a flange head bolt not tapered seat bolt.
  9. 5488 axle
    No, the bolster is different, it has bigger pivot pins, already did mine. Had to hang the whole radiator support on a hoist to swap the bolster.
  10. 5488 ac question
    Harbor Freight gauges I bought a year ago are good, only about $65
  11. TX 189 questions
    That's what I was thinking, IH spindles with a Case center housing. Thank you
  12. What is this on 1486?
    Thank you all so much. The dump valve linkage was missing, so he replaced it and adjusted it right and it shifts great. You guys' knowledge is amazing. Like its been said many times, keep the shift linkage lubed and the clutch adjusted and they shift fine.
  13. What is this on 1486?
    Can't get a pic to work, but on the side of the mcv there is a little block with a push button valve and linkage to press it when you step on the clutch. It was disconnected, my friend who has worked on these tractors since they were new said he's never seen one before.
  14. 440 baler
    Can anybody find a part # for the repair kit or get me a picture of where it goes?
  15. 1086 Hyd problem
    When my 186 did this it had a leak in the 3pt valve, not huge but resealing the valve fixed it
