robgIN
    29
Everything posted by robgIN
  1. 2017 IHCC #33 PLOWDAY
    Great video ! Well worth the wait, that was a good day and watching this I can almost smell the dirt again. I think everyone there enjoyed themselves.
  2. Chapter 33 plowday pics
    A nice fall day in northern Indiana had a good time plowing with this bunch of guys.
  3. Chapter 33 plowday pics
    Can't blame him, that one would be hard to part with, it cruised right along with that 4 bottom.
  4. Chapter 33 plowday pics
    I will do that, I think I got one of him also, but he was looking the other way. He was quite a guy, had some interesting stories .
  5. Chapter 33 plowday pics
    4 bottom on the 766 . Here's some more pics. There was a nice M with a semi mount but I must not have gotten a pic of it, hopefully someone else did.
  6. IH COLLECTORS #33 PLOWDAY
    My plan is to be there again this year, most likely with the rusty F-30 again. I have a 34 W-30 that used to live and work up in that part of the state that I would like to bring but I am not sure it is quite field ready yet so maybe next year for it. It has been a long time since it has been out in a field plowing. Should be another great day and I encourage anybody thinking about going to do so, it's a big field and most parts pull easy.
  7. Finished Project - McCormick No. 4 Tractor Plow
    I'm impressed with all 3 of them, the plow the M and the F-12, great job.
  8. Maybe dumb question, why no 1006 ?
    one of the old Harvester Highlights had an article on the F-40 and I believe 2 were built using the power improved 15-30 engine ( 22-36 HP ) . The article mentioned issues with crankshaft failures if I remember right and for various reasons they decided a larger row crop tractor was not feasible .
  9. Plow id
    looks like a 412 maybe
  10. VAN WERT PLOW DAY VIDEO
    Great video ! Lots of nice tractors there and always a great bunch of people.
  11. NW Ohio plow day
    Some neat pictures and videos, it was a nice day , ground was a bit tough in spots but I think a good time was had by all. Thanks to Mark, Scott Equity Exchange , the land owner and everyone else who helped put this on. As always a nice variety of colors out in the field and nice to see some young participants out there along with the rest of us.
  12. NW Ohio plow day
    I'll probably still give it a shot. I'm bringing my 2 bottom with new shares and it went in the ground a couple years ago when we had the 20 plus inches of rain in June then the ground turned to concrete in the fall . The dull worn share plows just scooted across the top of the ground that year. Maybe I should have been hoping for some rain today instead of wishing it would stay away.
  13. T-20 vs Cat22 (Video)
    T-20 used the same engine as an F-20 , with the addition of a water pump, not a 10-20, or F-30 engine. And what was that he was rolling uo ? LOL fun video
  14. Red 4WD Tractors, Book
    Me too !
  15. Got the 560 running today
    that went pretty quick ! It ought to be pretty lively now.
  16. Got my motor back
    the dyno does help Mark, but those pesky condenser failures still pop up, maybe I should just leave them run during lunch from now on. As of now I am planning on being there on the 12th with one of the F series, I think it is the F-20s turn again. You guys always have a good event with a good mix of tractors.
  17. Got my motor back
    If you need a dyno to break it in when you get it back together let me know, I have the M&W P400 that used to be in the local IH repair shop here in town back in the day. The F-series take awhile to get it warmed up.
  18. 8X28 H&F round spokes for an F-20
    you see a lot of 14.9-28s on roundspokes on F-20s so yes they will fit , they will be somewhat pinched and the tread rounded but with the right amount of air will work.
  19. IH 540 plow
    You could always turn it into a 3 bottom , Ohio Farmer has a nice plow that I believe started life as a 540 that has been cut down to 3 bottoms . A pretty common thing to do in this part of the country where clay is king.
  20. IH Little genius plow
    They don't have bearings , the wheels just run on the axles , so if you have play there is probably wear on the axle itself and maybe the hub but it is a pretty forgiving design so don't panic. If you take the lift wheel off there is a spacer with about 4 steps on it and a pin that holds the hub from having too much in and out play, this is probably worn down also. If the hub can move out too far it can slip off the dogs that catch to lift the plow. Or it may be full of old hard grease , or parts may be partially seized. Likely a little bit of all those is what you will find. Just take it apart , clean it up good , make sure nothing is broken and adjust it so the hub can't move to far back and forth. You may have to make a spacer from a piece of pipe or something to compensate for the worn adjuster but once you get it apart you will see it is not that complicated and nothing is going to fly out at you when you take it apart.I would hate to think how many miles some of those plows have traveled in their lifetime.
  21. trouble with F20
    If it is popping back through the air cleaner I would think sticking valve. I agree with the new plugs first , the carb screw is full rich at 3 and 1/2 turns out. You could try pulling the choke out a little bit to richen it up and see if that changes it , if it helps then probably a fuel problem , dirty carb , restricted fuel flow . Is the tank clean or does it have crud in the bottom ? With the carb set at full rich for heavy loads they will idle rough and rich and usually have black smoke , when people lean them out to make them idle smooth they will fall on their face when put under load.
  22. Credit card problem
    I have had Discover Card for around 14 years and they have been very good to deal with and like you said you get a human when you call pretty quick. Got a call from them once about a suspicious charge, wasn't me, they cancelled the card and sent me a new one . Think it was paypal breach that was the cause but I was impressed how soon they caught it.
