Turbo806
    9
About Turbo806
    central IL
    anything that enables me to be outdoors
  1. wheel weight
    i do not have any split weights. I bought full plates at a reasonable price thinking they would bolt on fine since there is a set on my 806 that seemd to bolt up without any issues. just wanting to do correctly and not cobbled up.
  2. wheel weight
    how do the full weights not fit to rim? what do I need to look for? I have an 806 with single full plate that seems to fit ok. If someone can tell me proper fit, I can look at other tractor and maybe those plates will work as stater weights to rim on my 1066. Thanks for the replies.
  3. wheel weight
    need some input on putting full wheel plates on 1066. was at a show this weekend and took pic of split weights hung using square head bolts, nicely done as well. Looking at my plates, it seems the full plates bolt on differently. obviously the first plate will bolt to rim using recessed squares, so I use outer holes which all line up no offset like split weights. using 3 per side. input or pics appreciated.
  4. wheel weight
  5. 66 series wheel weight
    I picked up some full wheel weights today for my 1066. Is there any place I can get new square head bolts or am I going to have to search for used?
  6. battery cable
    buying new set of 6v batteries today. Dont have tractor close by to measure. what is the approximate length cable I need to connect the two batteries across chassis? thanks. 06 series.
  7. wheel weight
    what is a good price for a set of split weights
  8. wheel weight
    do the 2 piece rear split weights weigh the same as the single unit? What are the respective weights for each? 06/66 series.
  9. 1066 needs more rear weight
    wow, if the tire looks that nice, what does the rest look like. Please share!! Thanks for comments, any advice on how much weight to start with?
  10. 1066 needs more rear weight
    pulling 4 bottom plow, alot of tire slippage. Havent used mounted chisel yet, but I am sure will have same issue. I just got this tractor and sold my 1566 with cab and duals. Never spun near as much. So hear is my question, do I go with mounted axle weights or add fluid in rears? Which would be better option?
