M turbo
    60
About M turbo
  • Birthday 01/09/1973
    Bothwell On.
    Anything with a motor on it, farmin' and critters.
201 profile views
  1. Dorman products make a repair kit.
  2. Has the bell housing been cut open to access the torque limiter?
  3. No man, just continuity at coil.... also what was the actual fuel psi ?.......needs to be 35+psi.....45psi be like more better.. The mare has sat for a spell, ALL electrical connections will be dirty(coil plug)....something overlooked should be the answer
  4. A set of 3.23 or 3.54 gears should be easy to find. An E4OD might be a difficult to find reasonably, then you need the powertrain module as well and must use '92 or earlier.
  5. Sounds like it'll run on the start circuit but quits on the run circuit. The start circuit ignition source is on the solenoid by the battery. No actual computer on it, just a powertrain module. I'd hook a test light to the coil power wire and see if it stays lit going from start to run....one possibility.
  6. If fuel pressure isn't high enough it won't start either, change the filter. I've had that happen before. You can get another 10psi by unhooking the vacuum line on the regulator if need be.
  7. That darn steiner catalogue is an expensive read...website is worse yet.
  8. Unfortunately this isn't a joke....must be muddy's cousin.
  9. With a pull/push headlamp switch, turn it anti- clockwise. Later S-lines with a rocker switch had door jam switches for the domelight....IIRC
  10. Excessive toluene to make the premium gas will do that.
  11. Your right, he is gonna get the block serviced at this point.
  12. Levi eventually gives up though.
  13. If you get good at cutting puzzle piece shaped ends, you could get away with cereal boxes and cheap bathroom calk too....Just add a little more sawdust to the used motor oil/hy-tran/def fluid crystal mystery stuff your putting back in after. Maybe a banana peel or 2 for a friction modifier as well.
  14. I suppose the residual Def fluid and any of the chrystalized bits of dried Def will only enhance the used hytran motor oil mix in your dad's allis.
  15. Damn Ford starters.......only good for a quarter century or so...
