new1206
    78
About new1206
  • Birthday 05/03/1963
    Shilo Manitoba Canada
    Rebuilding Vintage red tractors.
657 profile views
  1. Grinder mixers bearcat, nh, etc
    I grew up with New Hollands, can't beat them, worth the extra money IMO.
  2. 986 gear noise
    Which gear is gone? How do you know?
  3. Sad story, good job keeping that 9 away from the scrap man.
  4. 460 Utility diesel
    As i found out from the machine shop today I have a older serial # tractor with a newer serial number head. This guy has been in the engine rebuilding business for a lot of years, hoping he can fix me up with the right head gasket. Going to measure all pistons at TDC and see where i'm at. I only need 1 or 2 more thousands clearance and I'll be set. thanks for all the info guys
  5. 460 Utility diesel
    Thanks for the info Marty, I have pulled that particular piston (the one that was hitting) and there doesn't seem to be any wear on the wrist pin. Looking more and more like a faulty head gasket.
  6. 460 Utility diesel
    Sent the head off to the machine shop today but valves are opposite on each cylinder (intake and exhaust). I'll get some pictures of the pistons tomorrow.
  7. Baling rotary straw with an 8460
    Try running at about 2/3 PTO speed and it doesn't break up the straw as badly. You will have to slow down your ground speed a bit but the straw should at least get in the baler this way. Heavy dew helps too.
  8. 460 Utility diesel
    No didn't remove pistons from the rods. I didn't check thickness of the old gasket against the new one. Probably should have but have already thrown away the old one. will have to compare this one with the with the new one and see what's up.
  9. 460 Utility diesel
    Every piston seems to be stamped with a 2 and the divets in the piston are all exactly the same.
  10. 460 Utility diesel
    I was paying attention to connecting rod numbers when re-installing but you might be on to something. maybe pistons and connecting rods aren't matched up. i'll check it out. thanks.
  11. 460 Utility diesel
    Rod and the piston are the originals (didn't change them), the piston was in the correct position. Attached a couple pictures.
  12. Working on a project 460 utility and ran into something odd, was wondering if someone could give me a bid of insight on this. Recently replaced con rod bearings and rings, put everything back together and noticed i had a substantial knock. Pulled the pan off, plastic gauged all connecting rod bearings and mains and couldn't find anything out of the ordinary. Pulled the head off and found a shiny spot on #3 piston and also a corresponding spot on the head that was shiny. Assuming that the piston is hitting the head at this spot. It's on the high spot on the piston between where the pockets are for the valves. Has anyone out there heard of this happening before and what was the cause?
  13. Removing Roosa Master pump
    Remove the the timing cover on the pump. If the marks line up on the pump and the crankshaft pulley your on number one. If your on #6 the pump marks don't line up.
  14. SWD-9 sediment bowl bubbles
    Thanks for the info guys. I did put a new rubber/cork gasket on it but maybe I cut it a bit small. Will try to make another one and give it another try. Got my gasket material from Steiner tractor.
  15. Working on a SWDR-9 project and noticed today that the sediment bowl has bubbles coming back into it. Does this mean I'm getting air from somewhere or is this normal. Should the sediment bowl be full of fuel or is this the normal level?
