Drewu223
    83
About Drewu223
  • Birthday 03/22/1998
    Leeton, Mo
813 profile views
  1. Yes just with maxed out fuel screw, droop screw backed out, torque cam flipped up, and high idle screw backed out one turn.
  2. Well tonight was the tractor pull in Lincoln, Mo. And I was pulling 10,500 and 11,500 8mph classes. The first pull it ran just fine until about 200ft or so and it would just barley start coughing until it just shut off like you hit a kill switch. Got towed (very embarrassing btw) to the truck, and tried to prime the pump and got nowhere. I removed the secondary fuel filter and pumped the primer a few more times, then replaced the filter, and primed once more. Started up and ran great, revved flawlessly to about 2800rpm a few times, threw on the weights and pulled again in the 11,500 class. Same thing, about 200 feet and boom, it shuts off. After being towed again, I did the same thing as before to start it and load it onto the trailer. As I was leaving, a track official waved me down to hand me a shirt I apparently won, and said my injection pump is drawing too much fuel and that I need an in line electric pump to feed the injection pump. Does anyone else have any other ideas on what it could be? Keep in mind it's the factory American Bosch Model 100 10mm pump, just with max fuel, droop screw backed out, torque cam flipped up, and high idle screw backed out one turn.
  3. I was just curious what my 109 is worth. I have the engine but it's apart getting a complete overhaul, including a .030 over bore, .040 shaved off the head, new carburetor, coil, and many other little things. Also has a 48" (I believe) mower deck and 52" snow plow. I can't figure out just how to add a picture yet haha
  4. I plan to get an SFI rated flywheel and dual disk clutch by next year, until then I'm not gonna go a hair over 3000 rpms, if that. Too dangerous to myself and bystanders to have that much speed and heat on a cast flywheel
  5. They usually don't do that since they don't have an rpm limit, they just "recommend" a scatter blanket for over 3000rpms
  6. Does anyone how about how many RPMs you gain from a model 100 rotary pump when you turn the high idle screw out one full turn? I'm getting a Dakota digital tachometer sender soon unless I find a better way to run a tach. I'm at factory 2600 rpms now and I'm trying to get 2950-3000.
  7. How many of you guys have wheelie bars on your 66 series IH? The rules around here are changing so you have to have wheelie bars for anything above the 8mph class. Id like to run the 12.5 mph class but have to have a dead man's throttle and wheelie bars. I have the throttle figured out but does anyone have pictures or ideas for a good strong wheelie bar? Keep on mind it cant be a part of the hitch/drawbar
  8. I've just heard that that's what I should be at with a maxed pump, S2E turbo, and "H" head with smoothed ports
  9. Well I have a pull this weekend, and I'm pretty excited for it. It will be my first time pulling with the S2E turbo. I could use some tips though, like how do you raise your drawbar height? I have a shorter drawbar that's raised up about 1 1/2", but I'm not quite to the 20" from the ground limit. Also, what tire pressures do you guys usually run at? I have 18.4-34 rears, and I've been running them at 12 psi, I'm not sure if that's helping or hurting me. Keep in mind I'm at around 280-300hp now so I know I can run Hi-2 easily, maybe even Hi-3.
  10. I was looking at the rules of my pulling organization, and apparently for the open farm class I have to have a kill switch on the tractor, one that I can reach and one for the sled operator. I was thinking maybe a guillotine air kill but do you guys have any other ideas?
  11. Thanks yall. I was kinda thinking about $50/hr, but didn't consider travel
  12. I have a 1086 and a bush hog 2620 batwing mower, and people are asking if I can come mow stuff for them. What is a good price to charge? These places are within a 30 minute drive in the tractor, but only a few 2-5 acre properties.
  13. Does anyone know where I can get some interior parts? Such as knobs, gauges, etc. And the little plastic knob that shifts the 2 speed rear end
  14. My 966 does it as well, but I don't have a radio on it (who needs a radio with an S2E turbo and 4" straight pipe right?). Whenever I'm done using it I always disconnect the LH ground cable so it doesn't discharge. I'll have to do what 65806 said and test for parasitic draw when I'm home, except I'll be using the over priced snap-on meter instead of a Fluke haha
  15. Won't get interesting very fast, I'm living 10 hours from home at college working at a part time job between classes, I can only pull if there is any pulls scheduled back home during the same time as my 8-10 day long breaks from school every few months.
