Wisconsinred
    100
About Wisconsinred
647 profile views
  1. 5488 hydraulics. Signal check valve
    Our 54's hydraulics have always been slow to respond to get any flow from the motor valve you have to use the 1st auxiliary valve and put the pump in high pressure standby everyone said pull the middle plug out and see if it leaks, sprays a steady stream. Orderef signal check valve kit when I got it apart all that was in there was ball spring and retainer. The kit came with ball two springs Belleville washer and retainer and instructions and book are vague. What or should I go together as? Ball spring Belleville washer spring retainer?
  2. Who Rebuilds a TA that will last? 706-1586
    Sounds like most people I've talked to I'm not sure why we've had such good luck with them
  3. 5488 Sentry Module
    We had to get one from cih last year was $1600 parts manager cuts us a small break, haven't had a single issue with it worth it if you ask me because at that time Mike didn't have any on hand
  4. Who Rebuilds a TA that will last? 706-1586
    We Have mostly diode ta's in everything from the 1206 966 1086 the 3788 all used heavily never replaced a single one just my 2 cents literally thousands and thousands of hours on the diodes and 0 issues but have head from neighbors etc that they hate them not sure why, we like ours but the same tech did them all over the years he was best in our area could have A lot to do with It damn cancer.
  5. hello,
    was reading your post about the hydraulic seat accumulator and wondered if you had any luck.
    I have a 1066 and my accumulator has been non-charged since i bought the tractor 6 years ago.
    well now it is leaking where it screws onto the seat height cylinder. $400 just seems like too much to pay and was wondering if you found an alternative??
    My accumulator has the mfg sticker and part number on it.  It says it is Made by Greer Olaer and the part # is A66789 200.  I did a quick search and not being too computer savy I didnt get very far.
    I might cap my off unless a more reasonable price option is found
    1. Wisconsinred
      Wisconsinred
      Deere can get you one for about $100.00 cheaper otherwise no I haven't found anything. And anything used is probably going to be just like what you have but you may get lucky and find one that can be charged again. Almost sounds like you might just need an o ring where it screws on? And if the cylinder it's self is leaking you can reseal it too
    2. SAJ1000
      SAJ1000
      I ended up buying the Deere one. Like you said, It cost 335  but was about 100 cheaper.
      The threads on my original accumulator were a little messed up , but I charged it up with compressed air
      and it seemed to be holding...at least overnite.  Anyway , I figured after I spent alot of time on it
      ....it would probably leak down any way so I bought the deere one.
      thanks for the response
  6. 1586 vs 5088
    H1 direct is pretty far away from h2 ta on my 66 keep in mind much closer gearing on the 88s the 15 will be a large jump between each gear
  7. Reman 466 smoking
    We set the reman at 215 at rated on the dyno, but when we seen how it smoked under load I had him come out and turn it down 2 turns back down to what it was at on the original engine but that was not the issue pumps needs to be gone through.
  8. Reman 466 smoking
    After a long talk with mechanic that did the install we concluded new injectors or old pump going to send the pump out as soon as budget allows was hoping it was something cheaper but guess we shoulda did this in the beginning but we figured it was good
  9. Reman 466 smoking
    Can't seem to find any where only leak is exhaust at the manifold split
  10. Reman 466 smoking
    Checked time everything is at 18. I mentioned earlier my manifold is leaking where the two halves come together when we swapped we had it reground now it seals to the head perfectly but I don't remember it leaking here before, could this be some of the issue turbo not building enough pressure? Any fix for this or just replace? Just trying to eliminate possible items before throwing $$$$$ at it
  11. Hey ed what would it cost a guy to have an ambac 100 gone through? Thinking something internal is wrong just put in a reman 466 on our 1566 now it has a constant light amount of smoke everything is timed right it doesn't matter how hard your working smoke is always there when its working idles fine starts fine just smokes when it's working
    1. Injpumped
      Injpumped
      1000 to 1200 is pretty typical.
  12. IH 1066 Black Stripe
    Black stripes definitely look better like that than bright shiny new paint jmho
  13. IH 1066 Black Stripe
    Gotta love the patina on your tractors doesn't get much prettier!
  14. Reman 466 smoking
    Will do my intravance is rattling at idle don't matter if it's 30 wt or 15 -40 came to me with 15-40 we run 30 could that be some of the issue?
  15. Reman 466 smoking
    Brand new borg warner 3lm466 turbo, I'll feel the lines and listen close when I get to it today but I haven't noticed a beat to it
