Timothy56
    80
Everything posted by Timothy56
  1. What's your favorite snack
    As I am sitting here reading red power coffee shop. A couple of small nips of Jim Beam Honey is pretty good. Okay so maybe its more than a couple.
  2. What's your favorite snack
    Cheese curds. They have to squeak when you bite into them.
  3. Do wild corn dogs grow in your area?
    Always thought those were wild VEGETARIAN corn dogs.
  4. Corn Picking with the 14P and Farmall H
    This old gal has been resting in the same spot for 35-40 years. Are there serial numbers some where? I did not see any. Where should I look? What model is it?
  5. Silage packing tractor?
    The ultimate packing tractor the 4166. 4166 bought for $3250 7-8 years ago with PTO. 10 foot dagelman blade auction sale $500 came off a Case 2590. Step son made the mounting brackets. Just added to what was there. It is connected to the sides of the draw bar in back. $150 for the iron.
  6. Grinding hay in hog feed
    Back in the 80s we had a Gehl 120 grinder mixer with a bale conveyor with an hydraulic motor and flow control. Ground alfalfa, 3-5 bales per load with barley for the sows. Yes for protein and I am not sure but I think vitamin A.
  7. Down Corn
    Blast away I think the daily limit is 20 or may be its 30.
  8. Down Corn
    Couple hundred thousand snow geese will take care of a quarter section in a day or two. That is what going on here in central ND today even with 3-6 inches of new snow on the ground yesterday and today. You can hear them a mile or so away.
  9. National anthem protests
    Don't think Bud Grant (Vikings), Don Shula(Dolphins), Tom Landry(Cowboys) Chuck Knoll (Steelers) Vince ( Packers) would put up with crap like this.
  10. How dry is it in your area?
    Just out checking cows a few minutes ago and saw a gopher running across the pasture with a blade of grass and six cows chasing it. 2.98 inches since April first. There won't be a lot of cover for wildlife this winter as every low spot, slough, road ditch or any other green spot has been or will be cut for hay. Hay crop is one fourth to a third of average.
  11. 856 PTO clutch pack replacement
    Take the 4 bolts out that hold #67 on. Lift that off then take snap ring #60 off. Remove the disc and plates put the new ones back in in the same order as you took them out. Soak the fiber disc in Hytran before stalling. Once a every thing is in and snap ring back on slide the drive shaft #64 in but you may have to line up the disc as the drive shaft is going on. Try to line them by looking down the from the top and line them the best you then start installing the drive shaft slowly you may have turn it back and forth. Make sure the little O ring #70 is in place before #67 is all the way down. This is just to replace the clutch pack. If it needs more than that we take it to some who knows what else needs to be replaced. Most of the time it was $300-400 bill for complete overhaul.
  12. Seal on filter side on 1066
    Is this the right part number for the seal that fits on the short tube going from the filter side to the hitch pump? 1280599C1 It slides on the tube OK but when I fit it in place before having the tube was installed it was a little loose. Should fit tight? How tight? Thanks
  13. MTO church parking lot ?
    You mean like SOB (Sorry Old Bum)
  14. 2011 Silvarado NO START
    Fuses are all good? 40 amp ignition fuse under the hood?
  15. Cooling off
    Had a few minutes today 7-6-2017 to uncover a snow bank from 12-5-2016. The husky coyote cross found a cool spot today after the 102 temp yesterday. The snow was under about 2 feet of silage and hay that got pushed together with the snow after the early December blizzard. The snow was piled 12-15 feet high in this area.
  16. bobcat trouble
    Shoot it with your thermal temperature gun in different spots. See where it gets hot first.
  17. Pto clutch change help 1086
    Do you have it out of the tractor? There is a short bolt on the left lower side that gets forgot about sometimes.
  18. IH Radio fix
    The radio in the 1486 quit working. Can they be fixed in any way? Cause of failure was more than likely high voltage. Alternator went crazy so it maybe toast already. It was wired without a fuse. AM/FM MPX Radio W/8-Track Tape Model No. 111647C1
  19. Art From DeLeon Finds This Stress Relieving
    27 views so far how many of you tried it?
  20. 1066 won't move
    Just wondering do the hydraulics and or 3 point work?
  21. Hesston 565A Twine adjustment
    When the twine is cut is it a clean cut or is it torn off? Get an operators manual it explains some of your problem on page 92 of the 8465 book. Could be a numbers of things. I have had the shear bolt come just a little loose and then it takes longer to get the twine arm in the home position to cut the twine. Could be the twine arm is not turning freely.
  22. Water in my Oil - Rebuild D-206 Questions
    Are you going to loosen the oil drain plug before you start it to see how much water seeps out?
  23. Water in my Oil - Rebuild D-206 Questions
    How close to the shop? How far to the trailer for loading? Field repairs are no fun. Had a 915 combine that got water into the oil. We drained the oil and water. Filled with new oil and filters started it up and added the water. It ran ok sounded ok so used it for a couple of hours. Stopped let it cool down shut it down and drained the water right away. When we checked the oil the next day it looked good so we started it up and added the water again went for another hour or so and shut it down and drained the water again. Did this four or five times to finish harvest. Then over hauled the engine I don't remember what caused the water to leak into the oil but most of it leaked with the engine not running. I think the O rings in the sleeves were leaking.
  24. M stuck in 5th gear
    I think there is a bolt or pin at the bottom of the your shift lever. You might have to push down on the shift lever to slide the pin or bolt out. Once the bolt is out pull the shift lever up and look in the hole to see if all of the rails are lined up. If they are all lined up you should be in neutral if they are not use a bar and line them up. Good chance one is not lined up. Good luck
