Timothy56
    79
About Timothy56
  • Yahoo
    janicekh2002
    McLean County ND
    806,1066,1566,1486, 4166, 915, 97 & 2011 Black chevy
798 profile views
  1. What's your favorite snack
    Cheese curds. They have to squeak when you bite into them.
  2. Do wild corn dogs grow in your area?
    Always thought those were wild VEGETARIAN corn dogs.
  3. Corn Picking with the 14P and Farmall H
    This old gal has been resting in the same spot for 35-40 years. Are there serial numbers some where? I did not see any. Where should I look? What model is it?
  4. Silage packing tractor?
    The ultimate packing tractor the 4166. 4166 bought for $3250 7-8 years ago with PTO. 10 foot dagelman blade auction sale $500 came off a Case 2590. Step son made the mounting brackets. Just added to what was there. It is connected to the sides of the draw bar in back. $150 for the iron.
  5. Grinding hay in hog feed
    Back in the 80s we had a Gehl 120 grinder mixer with a bale conveyor with an hydraulic motor and flow control. Ground alfalfa, 3-5 bales per load with barley for the sows. Yes for protein and I am not sure but I think vitamin A.
  6. Down Corn
    Blast away I think the daily limit is 20 or may be its 30.
  7. Down Corn
    Couple hundred thousand snow geese will take care of a quarter section in a day or two. That is what going on here in central ND today even with 3-6 inches of new snow on the ground yesterday and today. You can hear them a mile or so away.
  8. National anthem protests
    Don't think Bud Grant (Vikings), Don Shula(Dolphins), Tom Landry(Cowboys) Chuck Knoll (Steelers) Vince ( Packers) would put up with crap like this.
  9. How dry is it in your area?
    Just out checking cows a few minutes ago and saw a gopher running across the pasture with a blade of grass and six cows chasing it. 2.98 inches since April first. There won't be a lot of cover for wildlife this winter as every low spot, slough, road ditch or any other green spot has been or will be cut for hay. Hay crop is one fourth to a third of average.
  10. 856 PTO clutch pack replacement
    Take the 4 bolts out that hold #67 on. Lift that off then take snap ring #60 off. Remove the disc and plates put the new ones back in in the same order as you took them out. Soak the fiber disc in Hytran before stalling. Once a every thing is in and snap ring back on slide the drive shaft #64 in but you may have to line up the disc as the drive shaft is going on. Try to line them by looking down the from the top and line them the best you then start installing the drive shaft slowly you may have turn it back and forth. Make sure the little O ring #70 is in place before #67 is all the way down. This is just to replace the clutch pack. If it needs more than that we take it to some who knows what else needs to be replaced. Most of the time it was $300-400 bill for complete overhaul.
  11. Seal on filter side on 1066
    Is this the right part number for the seal that fits on the short tube going from the filter side to the hitch pump? 1280599C1 It slides on the tube OK but when I fit it in place before having the tube was installed it was a little loose. Should fit tight? How tight? Thanks
  12. MTO church parking lot ?
    You mean like SOB (Sorry Old Bum)
  13. 2011 Silvarado NO START
    Fuses are all good? 40 amp ignition fuse under the hood?
  14. Cooling off
    Had a few minutes today 7-6-2017 to uncover a snow bank from 12-5-2016. The husky coyote cross found a cool spot today after the 102 temp yesterday. The snow was under about 2 feet of silage and hay that got pushed together with the snow after the early December blizzard. The snow was piled 12-15 feet high in this area.
