BullBozer
    7
About BullBozer
  • Birthday 12/12/1987
94 profile views
  1. Engine Knock
    It seems to stay consistent through all temperatures.
  2. Engine Knock
    Thanks again everybody. What does everybody think about in frame vs. complete overhaul? From my understanding the c200 is a sleeveless engine.
  3. Engine Knock
    Thank you for the responses so far. I should have added that it has about 5500 hrs. New 93 gas.
  4. Engine Knock
    Hi folks, I need some advice before I go spending a ton of money. I've recently purchased my third IH/Farmall, a 68 544 gas gear drive. It has developed a slight knock and I'm trying to figure out if it's valve, piston, or crank/bearing related. I changed the oil, old oil came out dark but no shavings at all. Put in straight rotella 30 with a bottle of lucas oil treatment, Fram filter. Knock is most noticeable at idle and goes away as you increases RPM. I unhooked the #1 plug wire and the knock goes away completely. The knock sounds higher in the engine. Any advice or relative experiences will be greatly appreciated. Ehere should i start? Different oil? Should I rebuild? Pull the head? Pull the pan? Thank you.
  5. 404 Seat
    Looking for an original 404 complete seat with frame. Anybody have any leads on one? Thanks, Nick.
  6. IH 404 Parts Needed
    Thank you!
  7. IH 404 Parts Needed
    Hi folks, my name is Nick and I'm new to this site/forum. Glad to be here. I'm in the process of restoring a 1962 IH 404 and I need some help finding some things to complete the tractor. I need: 404 emblem plate - IH part # 2754107R1 front lower grille pan - IH part # 379871R91 I've read on this forum that "That Emblem Guy" Jeff Foreman may be able to help with the emblem but I have been unable to find his contact info. Also, I've heard that there is a company making aftermarket front grille pans but haven't been able to find them. Any help with the completion of putting this little tractor back to factory original will be greatly appreciated. Thanks so much! -Nick
