Kelly T
    4
About Kelly T
  1. WD9 or TD9 injection pump seals
    Thanks Dave! This should help me out! Kelly T
  2. WD9 or TD9 injection pump seals
    I have tried but didn't come up with anything. Tried again and all I get is this tread. Kelly T
  3. Tried to send the following message to M Diesel but it says he doesn't accept messages. I hope I can reach him this way. this may have been discussed on here before but I am new to Redpower website. Thanks HI M Diesel. You were recommended to me from a fellow over on smokestack. I am looking for information on WD9 injection pump seals. Do you have numbers for seals for the main camshaft seals as well as the seals or packings in the Primary pump? Is there a way to change from the packing to a lip seal on the Primary pump shaft? Thank You Kelly Tytlandsvik
  4. Tried to send the following message to M Diesel but it says he doesn't accept messages. I hope I can reach him this way. this may have been discussed on here before but I am new to Redpower website. Thanks HI M Diesel. You were recommended to me from a fellow over on smokestack. I am looking for information on WD9 injection pump seals. Do you have numbers for seals for the main camshaft seals as well as the seals or packings in the Primary pump? Is there a way to change from the packing to a lip seal on the Primary pump shaft? Thank You Kelly Tytlandsvik
