WESnIL
    9
About WESnIL
96 profile views
  1. New to me pickup
    So, are you going to put some type of shellac or sealant on them?
  2. FAST HITCH COLLECTION
    To my knowledge there are only two other restored blowers in the US, one in WI and one in PA. And I do not know model numbers but parts inter-change is limited between the models. There are two others, one in MO and one in PA, awaiting restoration. They get lots of viewing at shows. Some (non-farm) people do not know what they are used for.
  3. Left Side Plow Chief points shears Needed
    If IH part number 515713R2 is what you are looking for I know where some are. They are 12 inch left hand Plow Chief shares. Call 217/586-3844.
  4. Coulter kit for IH Sub Soiler
    1legonutt, You also need the correct cone and hubs. I learned the hard way on some #39 plow coulters.
  5. One sees IH Sub Soilers from time to time. Nearly all of them do not have the coulter attached. Per the parts book the coulter was an integral part of the implement and not an option. Would there be a need/market for a 'coulter kit' for them? I know where there is a complete sub soiler with the correct arm brackets that one could use for a pattern for their reproduction. The cones and hubs should be available to complete the coulter kits. Then the next question is what would those with coulter-less sub soilers be willing to pay for a kit. It would only be economical to make a batch of the arm brackets. Everyone's thoughts are most appreciated before I proceed further with this idea.
  6. 340 parts book
    J Rockford Clutch, P Independent PTO -540 RPM, R - T/A w/provision for Transmission Driven PTO, S - T/A w/provision for 540 RPM Independent PTO, T- Cotton Picker Mounting Attachment (Low Drum), U - High Altitude Attachment, V - Exhaust Valve Rotator Attachment, W - Forward and Reverse Drive Attachments, X - High Speed Low and Reverse Attachments, Y - hydra touch power supply w/12 GPM pump, Z - 17 GPM pump, CC - 3rd speed heavy tillage gear attachment. Hope this helps.
