snowman656
    34
About snowman656
    Pompeys Pillar, Montana
245 profile views
  1. Red tractor and a green corn chopper
    No it shouldn't, farmer that I worked for in high school had the same set up and we chopped haylage and silage with no problem.
  2. Baling rotary straw with an 8460
    I have baled with a Hesston 565A which is basically the same machine. I had the same issue that you described and what I found that works the best is to get a little dew on it and it will make nice bales and will not plug up. Hope this helps.
  3. D301 injector pre combustion chambers
    Book says hole in the precup should be between 5 to 7 o'clock orientation. I put mine in my D282 at 6 o'clock orientation and starts just fine.
  4. 282/301 head differences
    Had a head done for a 656 a couple of years ago, you can only get the larger valves for them now.
  5. Hesston 565A Twine adjustment
    It is a clean cut when it cuts. Thanks for the info I'll take a look and see what I can come up with
  6. Hesston 565A Twine adjustment
    I have an issue with my 565A Hesston with the twine being delayed on the cutting it while it is tying the bale. All the rest of the tying cycle is correct except when it comes to the right side just before it is to be cut, so I end up with more wraps of twine on the right side than is needed. Since this is the same baler as a Case IH 8465 I was wondering if anyone has run into this issue and how to fix it.
  7. 560 Diesel overhaul
    It was a 656 but yes that is me. Went through that 282 more than I wanted but learned a lot about it.
  8. 560 Diesel overhaul
    I'm not sure how your pump is set up with your engine. If it is like the ones in the 656's there is two styles of pumps from what I have found out, the early ones had a advance on the timing gear and the later model engines the advance was in the pump. To me it almost sounds like your pump is not advancing and that could be why you are blowing so much smoke. Not sure if this helps or not.
  9. 656 oil filter adaptor
    I got mine from the local Case IH, at that time they were around $150 if I remember right.
  10. Heisler 9 Speed Manual, Farmall M
    Would you be willing to send me info on them as well. I have one in a Farmall M as well but have no info on them.
  11. Farmall 560 Diesel
    Just had a head rebuilt for my 656. When I got the new valves for it they only offer the larger valves for these engines now.
  12. Snowman got that 282 running?
    Ended up finding that the crank was out of a 236 and that the throw is different on them vs a 282. I got a crank from a 282 and had it polished and put it in after of course taking it pretty much all the way back down to nothing. Put it in the tractor and got my fuel system bled out and it fired right up, it is smoking a little bit but that is probably from the fuel that had been in there from before while I had the wrong crank in it. The longer it ran the cleaner it was running though, I don't want to run it too much though right now until I can get it on a dyno and get it broke in correctly.
  13. Snowman got that 282 running?
    Just wanted to let everyone know that I got my 656 running on Sunday. It sounds good and am excited to finish everything on it now. Will try to load a video of it running for everyone. Thanks for all the help that I got from you guys I really do appreciate it.
  14. Snowman got that 282 running?
    Lol basically that is what I have had to do. All I know is that the engine that I have is out of a rubber tired roller. When I got the tractor it didn't have a engine in it, it was also a bare back with a narrow front end. I put a wide front end under it and also put a 3pt on it as well. When I tore the engine down to begin with I had 4 bent rods in it and I had to completely rebuild everything in it so it has been quite a process on this tractor but its worth it to have it done.
  15. Snowman got that 282 running?
    I ended up pulling the engine out of my tractor and tearing it back down. I had the pistons in correctly but what I have found is that the pistons were not coming all the way to the top of the liners, they are about 3/8 of an inch below the top of the liners. I talked to a old case Ih guy and the only thing that he could think of is that it either has the wrong connecting rods or wrong crankshaft in it. He told me that it either had a D236 crank or rods in it. I am in the process of pulling the crank out of it and going to check what I have going on. I'll let you know what I find out.
