IHKeith
    41
About IHKeith
364 profile views
  1. gmc 2002 heater fan
    Usually a resistor problem will only affect lower speeds, this age of GM the control for the high speed relay is part of the resistor board and most likely the cause, it’s common enough for the plug to burn/melt at the resistor as well, both resistor and plug are available aftermarket, I’ve had the best luck with an AC Delco/GM resistor, the pigtail/connector is pretty much the same piece regardless of where it comes from, there is a panel that goes from passenger a pillar to trans tunnel that covers the duct, it is often tossed so it may not be in the way, the cabin filter is just above the passenger side of tunnel and is as mentioned ridiculously hard to get at, the resistor is in the duct below the glove box
  2. Stolen Tractors
    Back in the early 80s my great uncles (neighbors) had there MF20 joy rided, the perpetrators messed up some stooks of squares(funny even experienced operators could have some difficulties scooping them up, a little more finesse is required for that compressor to forking big bales), they ran that tractor off the field too, different time than now, the kids who did it got identified and worked off the damages, in more recent time(mid 90s up) we’ve had fuel siphoned and some random windows smashed from the lot here at home, once a thief tried to steal a snowmobile trailer with a front mount Toro mower on it, the mower had been loaded on trailer after repairs but had no straps or the hinge pin for tilting the trailer secured, when we came in the mower was off the trailer and the trailer was tilted and abandoned some feet ahead, there may be some professional thieves out there but most of the tractor/truck/car thefts over the years are just dumb kids, I haven’t come across many incidents(but still some)in the last 10 years or so, it does seem less frequent, maybe due to the prevalence of iPads and such
  3. Super nice 856
    My uncle's has a similar fade, it was repainted in the early 90s with Central Tractor paint
  4. self propelled round baler
    I had a good chuckle at the 'why are they turning' comment. My grampy was one of the first round balers in the area, he started with an IH 2400, not sure of the complete succession but eventually ended up with a Vermeer and was a dealer of Vermeer. I can't remember the exact operation of the 80s Vermeer balers but there was something about when they tied that you had to reverse. Grampy replaced his 2-105 White with a 2955 JD in the early 90s, he had some repeat rear diff issues with the 2955 and the Deere dealer blamed it on the Vermeer, some cockamamie reasoning about the repeat reversing. He eventually replaced the 2955 within a couple years with a 3255 but from a different dealer. It never had rear end issues but by then the Vermeer had auto tie and the 2-85 did the most of the baling until it gave way to a 6400 JD. The 3255 had 14000 plus hours with no diff issues when it left.To ramble on some more with stories of Grampy's farm, we were using the 3255 JD on an IH chisel Plow one day, I can't remember the model but it would have been the same vintage as a 45 vibra shank cultivator, about 8-10 feet wide, the 3255 was needed elsewhere so we hooked the chisel to the 1850 Oliver, which needed either to start before the batteries wore out on the warmest of days, but once she went ran good, the Olly pulled that chisel equivalent of a gear faster than the JD but sucked the fender tanks dry doing it. Anyway to hear of a Vermeer with a different unloading process made me wonder if a Deere was capable of handling that situation
  5. Harvestore Silos
    Gramps had a Harvestore and a Slurry store, he bought them in the 70s, used the silo til 85 when he got out of cows, the tank til 90 or so when he got out of pigs, the silo and the tank were both tore down in early 2000s and used as grain bins by the buyers. The base and bottom ring of the Slurrystore are still here. The Harvestore base is part of the loading dock now. I remember the roof rot issue being talked about, if I recall correctly when they replaced it the new one was to have a lifetime warranty.
  6. Rantoul show pics
    What brand is the yellow 4wd tractor in second last pic?
  7. Brand new IH 656 on the set of MayberryRFD
    Definitely a Chrysler product, look at the big old gas cap in the left rear quarter panel, its the kind of gas fill tube that runs through the trunk. I'm not sure of model, whether it be a Dart or a Valiant, it's an A body Chrysler for sure.
  8. 70 Fleetstar
    The White is a 4000 model, it's a similar build as the Fleetstar with a Cummins if I recall correctly
  9. 70 Fleetstar
    The owner is updating/restoring the truck to replace his rusting mid 70s White truck of similar configuration. Sad to see the White retired but the Fleetstar is a good replacement. Owner moves buildings and likes old iron.
  10. 70 Fleetstar
    It has a inline 6 Detroit with a blower, up until seeing this truck I thought all Detroits were V engines, it has a 13spd trans We are swapping the hubs out to allow budd wheels, 6 new Alcoa copies to go on, I'll post more pics when we make some progress
  11. 70 Fleetstar
    This old girl came in the shop today Rearend stamped with IH
  12. Lamborghini tractors
    My dad sold Lamborghini tractors for a few years, as mentioned before Lamborghini is owned by Same-Duetz Fahr(SDF). The Lambos were away around the deal Duetz had with Agco, there were Hurlimanns imported here in Canada too. If I remember right the head office of Same Duetz North America (as it was called in the early 2000s) was somewhere in Texas. The Lamborghinis quit coming when they were able to bring Duetz back. A 6105 White is a SDF tractor as well as the utility line from available from Agco at that time. When the Lambos were here they ranged from 30-165 pto hp.
  13. Porta Power exhaust pipe expander
    The company that makes my bender would be worth looking into. They call there exhaust line is called Blue Boy, there company name is AMH. Google will point you there. Our pipe bender has been a great machine, 7 years strong.
  14. Anyone else love working up stairs of old barns
    Got to love old barns, in one of my cousin's barn they had many tunnels, they filled the mow with squares as there chores and tunnelled in on their free time. The only rule stipulated by my uncle was to leave 4 tier untouched for insulation, by March the tunnels were done. My grampy and uncles were one of the first round balers in the area, they put them in a door of the loft and rolled them around into place. One of my uncle's said the last year they did all square there was 36000 of them, so I guess the grunt involved in rolling 50 rounds about would be better. A dairy farmer I once worked for was used to town kids for employees, and would throw the squares on the elevator at a leisurely pace. I told him to just feed it to me, it was 'fun' at the time to exert myself like that, when the wagon was empty, I'd still have bales to pile and John would fill a gallon water jug and send it up on the elevator before he grabbed the other wagon. I would drink the whole gallon and go again. If only I was still in that kind of shape. John's barn was an old tie stall bank barn, the granary could be seen only for a couple months then it was piled in. One thing I'm sure that anyone who has been around old lofts has seen many worn barn boards, it's neat how the grains are displayed on such a flat angle.
  15. Springer's Retirement
    Very nice!! A friend of mine traded his 89 Dyna for the same bike, also same colour, this season. He rented a '16 Road Glide while visiting his brother in Florida this past winter and said he had to have one. I haven't driven the newer bike, even though I've been given the chance. I'm a couple/few years away (financially) from replacing my 91 Electra Glide Ultra Classic. Congrats on the new toy!
