mader656
    3,580
Everything posted by mader656
  1. Had to break mine out to get up the hill to a customers house, rain thawed snow pack....sure are nice when needed...but I hate em....
  2. Beekeeping
    Our local apiary heads 2 hours North of you for almonds....
  3. how do you guys handle snowmoble trespass
    Half inch cold roll, I get them in 20 foot panels for less than I can purchase raw material for.... Horizontals are 1.25 pipe 14 gauge... I avoid sucker rod whenever possible it does not take weld good.
  4. how do you guys handle snowmoble trespass
    2 and 7/8 drill stem 8 foot half driven in the ground
  5. how do you guys handle snowmoble trespass
    This will stop them....
  6. fencing pictures
    Had to put a 2 3/8 drill stem into a 2 7/8 pipe easy if thereis no more oil residue, a challenge with a visible film, near impossible with a eigth inch of junk inside, I got it one inch In And the maul could not move it any farther, so i got bigger hammer, i did try and push it in with the loader first no luck, That made very short work.
  7. fencing pictures
    I haul 450 gallon of water 2x a week bad springs would not survive....
  8. how do you guys handle snowmoble trespass
    That's sarcastic, sadistic me....reality is I'd do 4 wire and signs marking it....
  9. how do you guys handle snowmoble trespass
    Does one wire at t posts every 100 constitute a fence or trap....
  10. fencing pictures
    I needed a press....it worked great....little fast however....
  11. Pickup chains...who else uses em..
    Yup chained up and stuck is never fun....last winter I was stuck in a drift 45 degrees tires chained, a foot off the dirt...10 feet from clear road....shovelas for 30 minutes gave up walked 3 miles home to get the tractor, today was the second time I've needed them since I joined the elite club of IH owners, (different chain used when stuck).... Today was the 2nd time in the last 3 winters...to too bad...
  12. Pickup chains...who else uses em..
    I've got 3 Good ones and the fourth needs repaired cut down semi chains too...the cams are nice too no bungies to break...
  13. State Senator From Rural Nebraska Wants This
    How dare you use The kings water...
  14. fencing pictures
    Nope thought I had a file....wrong... Rained and warm last night. And 6 inches of snowpack don't go together customers drive gains 300 feet in the 1/4 mile chains were needed to get up...to more time to get up the drive than finish....
  15. What is this??
    They park them on top the tallest hills they can here....
  16. fencing pictures
    Finally almost done...hit a rock with chain saw... No file to be found....half hour lift this wire would go up so much faster without the S*** on the the ground and having to shovel it...
  17. What welders say
    Between welding and barb wire I've given up on hole less work clothes...
  18. Ether (starting fluid) sickness?
    All my large bells ends passed the scanner this winter...4000 pounds of them...
  19. Ether (starting fluid) sickness?
    Most pipe I get is pretty clean...rarely do I get that stuff... Radiation from?
  20. Ether (starting fluid) sickness?
    Building fence I never get the pleasure of welding on clean steel... However the oil sludge from drill stem is nasty when it burns...
  21. snow shovel
    My v blade on the 656 Will slide the front end sideways with a big hard windrow, block of ice, rock, or gate post so a cub would slide easy. Course picking it up 2 inches changes that...
  22. Ether (starting fluid) sickness?
    A five gallon of tire lube goes a long way for safty when I did tire service we would pack it in the bead on a tire we could not get to seat...it would hold pressure long enough to get it to seat...then scrap it off for reuse...
  23. I dare you
    Clean eating....Your doing it wrong.....
  24. I dare you
    My phone is where 97 percent of my work comes from can't be without too long....
