BTD6NZ
    17
About BTD6NZ
    In the bush West Auckland New Zealand.
153 profile views
  1. Pilot bearing number. BTD 6
    Kevin, Thanks for that - 6208 was what I was looking for - should have done a search first.
  2. Pilot bearing number. BTD 6
    Kevin, Thanks for reply - the bearing shop here cannot recognize the International Part numbers in its system. I need a bearing makers number for this bearing or size - inside - outside - width. I am a work in Australia and the machine is in pieces back in New Zealand.If I was at home no problem but I am just trying to get a jump start on the job by getting bearings and seals together while I am at work. Thanks.
  3. Can anyone supply me with a bearing makers number for a steering clutch pilot bearing 53389D fitted between steering clutch shaft and steering clutch drum. Bearing shop cannot place International part number and I do not have old bearing with me. Thanks.
  4. Before going off shore check out Hamilton Tractor Parts - they quite often are parting out BTD 6s and 8s.Andrew Lusty www.vintagetractorparts.co.nz in Auckland or Trackweld in Hamilton might be able to point you in the right direction. Any parts for these machines are getting hard to come by - thats the reason I brought a parts machine for my going BTD6 - the only problem is now I am trying to get the parts machine going. Tom
  5. TD6D110 What is your location and serial number of machine, Thanks, Tom
  6. BTD 6 Serial numbers.
    Not the best but go to Trade me Farming - Tractors - Up to 50 hp and search International. Only 3 shots. Will counter you on the Hamilton Blade - have one on my BTD 6 and its angles like a breeze - but yes built like a brick outhouse - but not bad for 50 year old machine.
  7. BTD 6 Serial numbers.
    Mike, Thanks for that, decales long gone - red well worn - no sign of any yellow - has Simms Mini-Mec injection pump. Fitted out with Hamilton hydraulic blade.
  8. International BTD 6 serial numbers ran from 2401 in 1955 to 21033 in 1975. My question is did the long track frame model - 5 bottom rollers and 2 top rollers have a different serial number? The reason why I am asking is that I looked at a long frame model with a serial number of 690.
  9. BTD6 Clutch
    Just spent most of the day trying to fit clutch back into BTD6 dozer. This afternoon no further ahead than I was this morning. Are there any tricks to fitting clutch - followed book - but seem to come up short 1/2 to 3/4 inch with clutch input shaft up against clutch face on flywheel and transmission input shaft at other end. Help needed.
  10. Fuel Filter BD 264
    Having problems tracking down fuel filter 840 633 R91. The BD 264 engine fitted to my BTD 6 dozer has both primary and secondary fuel filters - some only ran a primary ? The 704 640 R 91 - no problem The 840 633 R91 came out of filter housing - no name or number - local Wix shop cannot match. Anyone have number or supply for this filter.
